I want to show data that doesn’t really belong on any known grid. I wanted to setup my map such that I can see the markers, and also a scale bar. In the future, I’d like to add a shapefile, grid, etc.
The code below shows 3 points from my datafile, that I wanted shown on the map. The points do show, however, the ScaleLineAdornmentLayer does not. I’ve also put these points into the MapSuite GIS editor, and I can get it to show the scale bar properly.
I’m wondering if there is a default projection (or some other setting) I can use to make my map show in the same was as the MS GIS editor?
(Note, because these are client supplied files, I don’t really have any idea of
the range of points to be displayed (eg in one file the X coordinate could
range from 0-300, in another it might be 50,000-60,000, but in all cases, assume the data is 1::1m
Steve
privatevoidWindow_Loaded(objectsender, RoutedEventArgs e){//wpfMap.MapUnit = GeographyUnit.Meter;wpfMap.MapUnit = GeographyUnit.DecimalDegree;
wpfMap.ZoomLevelSet =newGoogleMapsZoomLevelSet();
var pointLayer =newInMemoryMarkerOverlay();pointLayer.Columns.Add(newFeatureSourceColumn(“HOLEID”));
var uri =newUri(@“D:\Temp\AQUA.png”);pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointMarkerStyle.ImageSource =newBitmapImage(uri);pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointMarkerStyle.Width = 20;pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointMarkerStyle.Height = 34;pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointMarkerStyle.YOffset = -17;pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointMarkerStyle.ToolTip =“This is [#HOLEID#].”;pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
wpfMap.Overlays.Add(pointLayer);
pointLayer.FeatureSource.BeginTransaction();
var pointShape =newPointShape(60950.578, 10671.408);var pointFeature =newFeature(pointShape);pointFeature.ColumnValues[“HOLEID”] =“1”;pointLayer.FeatureSource.AddFeature(pointFeature);
pointShape =newPointShape(60950.894, 10675.447);pointFeature =newFeature(pointShape);pointFeature.ColumnValues[“HOLEID”] =“2”;pointLayer.FeatureSource.AddFeature(pointFeature);
pointShape =newPointShape(60950.928, 10680.07);pointFeature =newFeature(pointShape);pointFeature.ColumnValues[“HOLEID”] =“3”;pointLayer.FeatureSource.AddFeature(pointFeature);
pointLayer.FeatureSource.CommitTransaction();
// scale adornervar scaleLineAdornmentLayer =newScaleLineAdornmentLayer();wpfMap.AdornmentOverlay.Layers.Add(“ScaleLineAdornmentLayer”, scaleLineAdornmentLayer);
wpfMap.Refresh();}
blastholecollars5204002.zip (2.39 KB)
