Size of map synchronized with the browser window
if I set the 'height' and 'width' properties of the map to 100% the map is no longer displayed in the browser window.
How can I cause the map size to be synchronized with the size of the browser window it is displayed in.
Thanks for help
Tom
Tom,
 Thanks for the post.
Add the attached style node to the header, the problem will be solved. If the map control is within another div, you should also make sure the height of that div is set to 100% too.
That’s an issue of HTML, just create a blank page and add a simple div, you can see the same issue. Fortunately, it’s easy to solve. :)
64-ScriptForTom.txt (195 Bytes)
