I noticed that lines look jagged when looking closely like they are drawn without anti-aliasing. Is this normal or is there a way to “smooth” lines out?
Smoothing jagged lines
Hi Dan,
Could you please show us the code or let us know how to reproduce it?
Generally I think if it’s vector data it will still render smooth enough after you zoom in.
Hi Ethan, I’m just loading normal shapefiles containing line features. Below is a screenshot I took, zoomed in to show some of the lines. See how they are jagged, and look like “steps”?
Here’s another one, but not zoomed in:
These lines have anywhere from ~400 to ~1500 vertices, with each vertex being very close to the next. Here’s how some of these vertices look just to show how close they are:
I noticed when drawing lines using the trackoverlay, I do not see any of the jaggedness.
Hi Dan,
I think that’s related with some property you set, could you please modify this sample:9608.zip (10.6 KB)
So we can see what’s the problem.
And your first screen shot is not a correct map, it should be a stretched image from higher level, which means your current hadn’t render complete.
For my LineStyles, I have a class that inherits from LineStyle. Here’s the class:
public class MyLineStyle : LineStyle
public GeoColor PenColor
get;
set;
public MyLineStyle(Color? penColor, int penWidth)
PenColor = GeoColor.FromArgb(penColor.Value.A, penColor.Value.R, penColor.Value.G, penColor.Value.B);
CenterPen = new GeoPen(PenColor, penWidth);
CenterPen.DashStyle = LineDashStyle.Solid;
CenterPen.SetLineCap(DrawingLineCap.Flat, DrawingLineCap.Flat, GeoDashCap.Flat);
The layers containing these line features are InMemoryFeatureLayers. For these layers, here are the properties I’m setting:
inMemoryFeatureLayer.DrawingQuality = DrawingQuality.HighSpeed;
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel101.DefaultLineStyle = myLineStyle;
Here are the properties I set for the Overlay containing these layers:
overlay.TileType = TileType.SingleTile;
overlay.DrawingQuality = DrawingQuality.HighSpeed;
overlay.TransitionEffect = TransitionEffect.None;
That’s all I’m doing.
Hi Dan,
I still hadn’t reproduced it after change the code.
You can keep zoom into the deepest level its scale nearly equal 1, and see the line still render clearly.
I think you still missed some code about it.
You can try to modify the high speed to high quality to see whether it render correct in your project.
And I wish you can reproduce that in the sample project, so we can help find the reason.
9608.zip (10.9 KB)
