[Solved] How to use the MapSuite control in an MVC Razor view
We have just purchased the MapSuite Web Edition product and would like to integrate it in our ASP.NET MVC 3 web site. I have followed the tutorial in your Wiki using the IMapInitializer controller and created an ASCX which wraps the Map control.
However, when I try to render this user control on my Razor-enabled View using the Html.Partial() method it does not work. It just shows a blank area where the map is supposed to be.
@Html.Partial("MapControl");
It works fine if I add the control to an ASPX view.
Is there any known workaround to this? I find it strange that 2-3 years after ASP.NET MVC was released, there is still no official support in MapSuite for this technology, which is quickly becoming the preferred choice for modern web site development.
I have investigated this a bit further and found something interesting. More specifically I compared the source code of the ASPX view to the Razor view, and the following caught my eye:
 ASPX view (working):
<table id=“map_MapContainer” cellpadding=“0” cellspacing=“0” border=“0” style=“width:1024px;height:768px;”><tr><td style=“text-align:left;background-image:url(bg_GeoResource.axd?ClientID=map_Map&PageName=FleetManager&Fresh=5608568&Format=image/png&Quality=100);margin:0px;height:100%;overflow:visible;”><div id=“map_Map” style=“height:768px;width:1024px;”>
 Razor view (not working):
<table id=“1_MapContainer” cellpadding=“0” cellspacing=“0” border=“0” style=“width:1024px;height:768px;”><tr><td style=“text-align:left;background-image:url(bg_GeoResource.axd?ClientID=1_Map&PageName=FleetManager&Fresh=58405840&Format=image/png&Quality=100);margin:0px;height:100%;overflow:visible;”><div id=“1_Map” style=“height:768px;width:1024px;”>
 The interesting part if the ID attribute of the table and div. For the Razor view, it is assigned ‘1_Map’ for some reason while for the ASPX view it is ‘map_Map’.
 This ID is used for naming of the autogenerated javascript elsewhere on the page, such as this code block:
<script type=“text/javascript”>
//<![CDATA[
WebForm_InitCallback();var json1_Map={“resolutions”:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,8.58306884765625E-05,4.291534423828125E-05,2.1457672119140625E-05,1.0728836059570313E-05,5.3644180297851562E-06,2.6822090148925781E-06],“cid”:“1_Map”,“uid”:“1$Map”,“currentExtent”:{“left”:-131.22,“bottom”:16.91,“right”:-54.03,“top”:55.05},“cursor”:“default”,“baselayerid”:“StaticOverlay”,“staticOverlay”:{“w”:256,“h”:256,“transitionEffect”:“resize”,“singleTile”:“0”,“buffer”:0,“clientCache”:{“cacheId”:""},“imageFormat”:“image/png”,“jpegQuality”:100,“singleThread”:false,“visibility”:true,“otype”:“LAYER”,“extra”:“271158405840”,“projection”:“EPSG:4326”,“wrapDateLine”:“0”,“name”:“StaticOverlay”,“opacity”:1,“displayInLayerSwitcher”:true,“isBaseLayer”:true,“Id”:“StaticOverlay”,“tick”:false,“AutoRefreshMilliseconds”:0},“layers”:[{“parameters”:{“LAYERS”:“WorldMapKitLayer”,“STYLES”:“WorldMapKitDefaultStyle”,“CLIENTMODE”:“Web”,“SRS”:“EPSG:4326”},“transitionEffect”:“resize”,“singleTile”:“0”,“w”:256,“h”:256,“format”:“image/jpeg”,“otype”:“WMS”,“uris”:[“worldmapkit1.thinkgeo.com/CachedWmsServer/WmsServer.axd",“worldmapkit2.thinkgeo.com/CachedWmsServer/WmsServer.axd”,“worldmapkit3.thinkgeo.com/CachedWmsServer/WmsServer.axd”,“worldmapkit4.thinkgeo.com/CachedWmsServer/WmsServer.axd”],“wrapDateLine”:“0”,“tick”:false,“visibility”:true,“name”:“62c72223-7dc6-40f4-8264-06365d99a965”,“opacity”:1,“displayInLayerSwitcher”:true,“isBaseLayer”:true,“Id”:“62c72223-7dc6-40f4-8264-06365d99a965”,“AutoRefreshMilliseconds”:0}],“editOverlay”:{“mode”:“None”,“editSettings”:{“drag”:true,“reshape”:true,“resize”:false,“rotate”:true},“features”:[],“style”:{“fillColor”:"#0033FF",“fillOpacity”:0.31372549019607843,“strokeColor”:"#0033FF",“strokeOpacity”:0.62745098039215685,“strokeWidth”:1},“otype”:“VECTOR”,“visibility”:true,“name”:“EditOverlay”,“opacity”:1,“displayInLayerSwitcher”:false,“isBaseLayer”:false,“Id”:“EditOverlay”,“tick”:false,“AutoRefreshMilliseconds”:0},“highlightOverlay”:{“highlightStyle”:{“fillColor”:"#FF3300",“fillOpacity”:0.31372549019607843,“strokeColor”:"#FF3300",“strokeOpacity”:0.62745098039215685,“strokeWidth”:1},“click”:false,“features”:[],“style”:{“fillColor”:"#0033FF",“fillOpacity”:0.31372549019607843,“strokeColor”:"#0033FF",“strokeOpacity”:0.62745098039215685,“strokeWidth”:1},“otype”:“VECTOR”,“visibility”:true,“name”:“HighlightOverlay”,“opacity”:1,“displayInLayerSwitcher”:false,“isBaseLayer”:false,“Id”:“HighlightOverlay”,“tick”:false,“AutoRefreshMilliseconds”:0},“controls”:{“Measure”:{“measureType”:“PathMeasure”,“displaySystem”:“metric”,“geodesic”:false,“enabled”:false},“TouchNavigation”:{“enabled”:true},“AnimationPan”:{“delay”:300,“onClientClick”:"",“enabled”:false},“LayerSwitcher”:{“onLayerChanged”:"",“roundedCornerColor”:"#DDDDDD",“activeColor”:"#DDDDDD",“baseTitle”:"",“switchTitle”:"",“enabled”:false},“Navigation”:{“wheelDisabled”:false,“zoomBoxKeyMask”:“1”,“enabled”:true},“MousePosition”:{“showType”:“lonlat”,“enabled”:false},“OverviewMap”:{“maxRatio”:24,“minRatio”:8,“enabled”:false},“PanZoom”:{“zoomWorldIcon”:true,“enabled”:false},“PanZoomBar”:{“zoomWorldIcon”:true,“enabled”:true},“ScaleLine”:{“enabled”:false},“Logo”:{“enabled”:false},“KeyboardDefaults”:{“slideFactor”:75,“enabled”:false},“LoadingImage”:{“w”:0,“h”:0,“enabled”:false}},“units”:“DecimalDegree”,“onClientDrawEnd”:"",“onClientEditEnd”:"",“onClientClick”:"",“onClientExtentChanged”:"",“onClientBaseOverlayChanged”:"",“onClientDoubleClick”:"",“popups”:[],“pageName”:“FleetManager”,“click”:false,“dblClick”:false,“baseOverlayChanged”:false,“hasTrackShapeEnd”:false,“extentChanged”:false,“centerX”:-92.625,“centerY”:35.98,“zoom”:-1,“rootPath”:"/”};
var parser1_Map=new mapParser(json1_Map);
Sys.Application.add_load(keepsession);
Sys.Application.add_load(CreateAllMaps);
function CreateMap1_Map(sender,args){};
Sys.Application.add_load(CreateMap1_Map);
var 1_Map = new ThinkGeo(‘1_Map’);
function CallServerMethod1_Map(args, context) {
WebForm_DoCallback(‘1$Map’,args,AutoRefreshCompleted,context,null,false);
</script>
 As far as I know, javascript variables cannot start with a number. Can this be the reason for the problem? I can also add that IE reports “Identifier expected” javascript error on the following line:
 The question then becomes, why is MapSuite doing this and how to avoid it?
 I hope this can help.
Problem solved!
 For those interested, the solution was to make use of the new ClientIDMode attribute which was added in ASP.NET 4.0:
 <cc:Map ID="Map" runat="server" Height="768" Width="1024" ClientIDMode="Static">
 By default, the client id is generated automatically which seemed to screw up the MapSuite markup for some reason in combination with Razor.
Sindre,
 Thanks for your post, I hope you can enjoying the Map Suite.
Sindre,
   We are going to be releasing some notes on how to use the Web Edition with MVC over the next few weeks.  We have been watching the technology and have helped uses get it working in previous versions.  Microsoft has been rolling out a bunch of different technologies and they are all a bit different.  You had stock webforms, which inst the new hotness but still is in high demand from our customers, they trotted out update panels, then MVC etc.  MVC didn’t get that interesting until version two or three.  I will agree that it is really picking up steam and we will defiantly support it.
Hello all,
It may interest you to know that in response to feedback like yours, we have developed and launched a new Map Suite control dedicated to ASP.NET MVC development.  The initial beta of Map Suite MVC Edition is available for immediate download; if you're still interested in MVC development with Map Suite, this is the edition for you.  It's ideally suited to targeting mobile and touch-based devices and gives you greater control than Webforms in numerous areas.
You can find more information about the MVC Edition here.
Let us know if you have any questions, or feel free to post your comments in the MVC Edition forum!
Thanks for using Map Suite,
The ThinkGeo Team
