Specify CRS with WmsRasterLayer
MapEngine engine = new MapEngine();
engine.CurrentExtent = ExtentHelper.GetDrawingExtent(CommonExtents.Europe, width, height);
WmsRasterLayer wmsRasterLayer = new WmsRasterLayer(new Uri(“localhost:8080/service?”));
wmsRasterLayer.UpperThreshold = double.MaxValue;
wmsRasterLayer.LowerThreshold = 0;
wmsRasterLayer.Open();
foreach (string layer_name in wmsRasterLayer.GetServerLayerNames())
   wmsRasterLayer.ActiveLayerNames.Add(layer_name);
// GetRequestUrl for debug
string requestUrl = wmsRasterLayer.GetRequestUrl(engine.CurrentExtent, width, height);
System.Diagnostics.Debug.WriteLine(requestUrl);
wmsRasterLayer.Close();
engine.StaticLayers.Add(“wmsImageLayer”, wmsRasterLayer);
Bitmap bitmap = new Bitmap(width, height);
engine.OpenAllLayers();
engine.DrawStaticLayers(bitmap, GeographyUnit.Meter);
engine.CloseAllLayers();
What I’m after is the moral equivalent of this OpenLayers code.
 map = new OpenLayers.Map(‘map’, {
          maxResolution: 156543.033928,
          maxExtent: new OpenLayers.Bounds(-20037508.3428, -20037508.3428, 20037508.3428,
20037508.3428),
          projection: new OpenLayers.Projection(“EPSG:3857”)
        var layer = new OpenLayers.Layer.WMS( “WMS gm_layer”,
            “…/service?”,
            {layers: “gm_layer”, format: “image/png”, srs:“EPSG:3857”,
             exceptions: “application/vnd.ogc.se_inimage”, transparent: true},
            {singleTile: true, ratio: 1, isBaseLayer: true} );
        map.addLayer(layer);
Hi Jeremy,
In WmsRasterLayer, there is a property "Crs" to define the target epsg in the server. Some partial codes like this:
WmsRasterLayer wmsImageLayer = new WmsRasterLayer(new Uri("localhost:8080/service?"));
wmsImageLayer.SendingWebRequest += new EventHandler<sendingwebrequesteventargs>(wmsImageLayer_SendingWebRequest);
wmsImageLayer.UpperThreshold = double.MaxValue;
wmsImageLayer.LowerThreshold = 0;
wmsImageLayer.Crs = "EPSG:3857";
The SendingWebRequest event is register to help us to see the request information.
Hope it helps and if there is anything i misunderstand, please feel free to correct me.
Troy</sendingwebrequesteventargs>
Hi Jeremy,
            wmsImageLayer.SendingWebRequest += new EventHandler<SendingWebRequestEventArgs>(wmsImageLayer_SendingWebRequest);
 Besides, please make sure the base projection is also under the mercator.
