I downloaded and used the Split Polygons Based on Gird program, which ran fine. However, when I load the produced shapefies into my map, I am seeing the grid lines, though they are very light. Here is the code that loads one of the files:
Dim countriesLayer1 As ShapeFileFeatureLayer = New ShapeFileFeatureLayer(Folders.HurrevacAppDataDirectory & _ "\countrieswoUS_areasplit.shp") countriesLayer1.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(landColor) countriesLayer1.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.Color = GeoColor.StandardColors.Transparent countriesLayer1.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.Width = 0.0 countriesLayer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
I’ve tried removing the references to the outlinepen, but with the same results. Likewise, when I load the _linesplit.shp file, I can’t get the boarder lines to draw, though they do appear, again very lightly. Any thoughts on how I can get these lines displaying (or not) correctly?
The _linesplit layers are working as expected now with that change. However, with the _areaaplit layers, I can still see the faint outline of the grid. Any ideas on why that might be?
About the _areaaplit, the reason for the outline remaining in the iamge is that actually we first creat some SplitPolygons that can cover the entire map like the following image,
then foreach the SplitPolygons we use intersectionPolygon=SplitPolygon .GetIntersection(WorldPolygon), so the edge of the SplitPolygon will become the edge of the intersectionPolygon
It is suggested to use _linesplit, because it coudl forbidden the outline problem.
