SQL to Tab file
I’m having an issue getting a SQL Layer to save to a Tab File, but keep getting an error with the columns or the call to save the tab file just closes the app, The SQL Table is just a table created using MapInfo 11.  I’m new to thinkgeo. Anyone got any pointers?
error:  A first chance exception of type ‘System.ArgumentException’ occurred in mscorlib.dll: Destination array was not long enough. Check destIndex and length, and the array’s lower bounds.
Code:
        static void CreateTabFROMSQL()
            string connectString = “Data Source=localhost\SQL2012;Initial Catalog=AGDAT_FARMMAP_AGTRIX;Persist Security Info=True;Integrated Security=True;”;
            MsSql2008FeatureLayer sql2008Layer = new MsSql2008FeatureLayer(connectString, “T_FARM_CUR”, “MI_PRINX”);
            sql2008Layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
            sql2008Layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            sql2008Layer.Open();
            var columns = ViewToTabColumns(sql2008Layer.FeatureSource.GetColumns().ToList(), “MI_PRINX”);
            var bbox = sql2008Layer.FeatureSource.GetBoundingBox();
            var features = sql2008Layer.FeatureSource.GetFeaturesInsideBoundingBox(bbox, ReturningColumnsType.AllColumns );
            TabFeatureSource.CreateTabFile(@".\MyTab1.TAB", columns, features);
            TabFeatureLayer.BuildIndexFile(@".\MyTab1.TAB", BuildIndexMode.Rebuild);
            Console.WriteLine(“complete”);
            Console.ReadLine();
        static List<TabDbfColumn> ViewToTabColumns(List<FeatureSourceColumn> fscs, string IDField)
            List<TabDbfColumn> columns = new List<TabDbfColumn>();
            foreach(var fsc in fscs)
                Console.WriteLine(fsc.TypeName);
               // if (TypetoColumnType(fsc.TypeName) != DbfColumnType.Null && fsc.ColumnName  != IDField)
                columns.Add(new TabDbfColumn(fsc.ColumnName, TypetoColumnType(fsc), fsc.MaxLength, TypetoDecmial(fsc), true, true));
            return columns;
        static DbfColumnType TypetoColumnType(FeatureSourceColumn col)
            switch(col.TypeName)
                //case “Logical”: return DbfColumnType.Logical;
                //case “Memo”: return DbfColumnType.Memo ;
                case “Date”: return DbfColumnType.Date;
                case “DateTime”: return DbfColumnType.DateTime;
                case “Int16”: return DbfColumnType.IntegerInBinary;
                case “Int32”: return DbfColumnType.IntegerInBinary;
                case “Double”: return DbfColumnType.DoubleInBinary;
                case “String”: return DbfColumnType.Character;
                case “Guid”: return DbfColumnType.Character;
                case “Float”: return DbfColumnType.Float;
                case “Decimal”: return DbfColumnType.Float;
                case “Numeric”: return DbfColumnType.Numeric;
                //Geometry
            return DbfColumnType.Null;
        static int TypetoDecmial(FeatureSourceColumn col)
            switch (col.TypeName)
                case “Double”: return 6;
                case “Float”: return 6;
                case “Decimal”: return 6;
                case “Numeric”: return 6;
            return 0;
Hi Patrick,
It should be two reasons, and please try modifying the code as following:
1.  Change the TypetoColumnType method to:
                //case "Logical": return DbfColumnType.Logical;
                //case "Memo": return DbfColumnType.Memo ;
                case "date":
                case "datetime":
                case "int":
                case "double":
                case "nvarchar":
                case "float":
                case "decimal":
                //case "Numeric": return DbfColumnType.Numeric;
                //Geometry
                case "float": return 6;
                case "decimal": return 6;
            return 0;
 2. Change the parameters of initializing the “TypeDbfColumn”:
new TabDbfColumn(fsc.ColumnName, TypetoColumnType(fsc), fsc.MaxLength, TypetoDecmial(fsc), fsc.ColumnName == IDField, fsc.ColumnName == IDField)
Thanks Johnny, no luck with your suggestion. Tried those changes but application just terminates on the line …
    TabFeatureSource.CreateTabFile(@".\MyTab2.TAB", columns, features);
I’ve used this command successful when I define a feature table from scratch . Wondering it I should be using a different approach? Is there a exporter class or save as methods I’m missing.
Hi Patrick,
 Would you please attach the test database here? If it’s big than the allowed upload size, please update it to forumsupport@thinkgeo.com. Based on the description shown above, there should be some problems with the data in this table “T_FARM_CUR”.
Thanks Johnny and apologies for the delay.
I’ve attached the project as a zip file. I’ve included in it a file "data.SQL" that contains the table definition and data.
Patrick
FileFileImportExport.zip (20.2 KB)
Hi Patrick,
Sorry for the waiting and thanks for the db definition.
I found the issue can resolve with the below codes:
               case "date":
               case "datetime":
               case "nvarchar":
               case "int":
               case "double":
               case "float":
               case "decimal":
               //Geometry
As The Tab columns can’t detect the IntergerInBinary and doubleInBinary, so we need to switch to float.
Please let us know if any questions.
