SQLite error (5): database is locked
MapSuite Team,
While in Visual Studio Debug mode I notice the below lines in the Output Debug Window:
SQLite error (261): database is locked
Fifteen of my layers are in their own unique SQLite database(one layer per database).
I’m getting this error when the extent changes and/or ZoomLevel changes as well as on a Center Map. This occurs frequently that it concerns me, but it does not happen all the time. I’m sure it’s a timing issue.
Sometimes both the 5 & 261 errors are received when a center map is performed.
I have multiple Map Overlays with each having a mixture of SQLite Layers and ShapeFileFeatureLayer. When the Overlay is set to DoNotLock the 5 & 261 errors are encountered. When set to Lock only the 5 error is encountered.
I’m currently using V9.0.0.190.
Any advice on this?
Dennis
Hi Dennis,
Thanks for the feedback. I recreated this issue which I will let out developers know that.
There is a workaround for this: please try changing the overlay.TileType = TileType.SingleTile to avoid that.
Any updates I will let you know.
Peter
Thanks Peter. Would you post when the fix is available in a build?
Dennis
Hi Dennis,
I did more research and found that this issue may be caused by the “database busy” issue. Please try setting the “Busy Timeout” to a proper value.The connection string like:
@"Data Source=catalog;Version=3;ReadOnly=True;Busy Timeout=60;"
More information about that please refer to http://www.sqlite.org/faq.html#q5.
Peter
Peter,
I believe that both of my SQLite posts are interrelated, which I did not realize at first. I am successful at setting journal mode = off. Once it was off then no more SQLite database locked errors.
I will still add ReadOnly=True;Busy Timeout=60 to the connection string.
Thanks for your assistance.
Dennis
Hi Dennis,
Thanks for the sharing. It’s very helped for the others who encounter the same issue.
Peter
