Hi Chuck,
If what I am guessing is correct, you are a complicate fields for a text style. If yes, here is a solution for your case. For instance, we defined a complicated fields like:
string complicateFields = “[FENAME]” + Environment.NewLine + “[FETYPE]” + Environment.NewLine + “[LENGTH]”;
Then, we register the DrawingFeatures event and apply this field to the textstyle:
ShapeFileFeatureLayer austinStreetsLabelLayer = new ShapeFileFeatureLayer(@"…\SampleData\Data\austinstreets.shp");
austinStreetsLabelLayer.DrawingFeatures += new EventHandler<DrawingFeaturesEventArgs>(austinStreetsLabelLayer_DrawingFeatures);
TextStyle labelText = new TextStyle(complicateFields, new GeoFont(“Arial”, 12), new GeoSolidBrush(GeoColor.SimpleColors.Black));
labelText.Mask = AreaStyles.Forest1;
void austinStreetsLabelLayer_DrawingFeatures(object sender, DrawingFeaturesEventArgs e)
foreach (Feature item in e.FeaturesToDraw)
string complexColumnValue = item.ColumnValues[complicateFields];
string[] splitNewLine = new string[]{Environment.NewLine};
string[] trimFields = complexColumnValue.Split(splitNewLine,StringSplitOptions.RemoveEmptyEntries); // remove the space field and the new line charactors
item.ColumnValues[complicateFields] = string.Join(Environment.NewLine, trimFields);
With the above method, we can filter the empty field and the line. The below is the result:
If that is not what you are looking for, would you please attach your codes on how to define the label styles?
