Yale,
  I wrote a sample app according to the requirements of Carlos Angelo where you track a reactangle, edit it and then stop showing the editing options and be able to track a new rectangle again by clicking on a button . See the code below. An error occurs at the line winformsMap1.Refresh(); in btnMisc_Click. Why is this error happening? Am I doing something wrong or is it a bug?
Carlos Angelo,
 Thank you for your patience. What you are asking is possible and we will show you the final result after we resolve those issues.
private void LoadPost9069()
    winformsMap1.ThreadingMode = MapThreadingMode.SingleThreaded;
    winformsMap1.CurrentExtent = new RectangleShape(-84, 11, -64, 0);
    winformsMap1.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 198, 255, 255));
    winformsMap1.TrackOverlay.TrackEnded += new EventHandler<TrackEndedTrackInteractiveOverlayEventArgs>(TrackOverlay_TrackEnded);
    winformsMap1.TrackOverlay.TrackMode = TrackMode.Rectangle;
private void TrackOverlay_TrackEnded(object sender, TrackEndedTrackInteractiveOverlayEventArgs args)
    winformsMap1.TrackOverlay.TrackShapeLayer.InternalFeatures.Clear();
    winformsMap1.TrackOverlay.TrackMode = TrackMode.None;
    RectangleShape rectangleShape = (RectangleShape)args.TrackShape;
    winformsMap1.EditOverlay.EditShapesLayer.InternalFeatures.Add(new Feature(rectangleShape));
    winformsMap1.EditOverlay.CanRotate = true;
    winformsMap1.EditOverlay.CanAddVertex = true;
    winformsMap1.EditOverlay.CanDrag = true;
    winformsMap1.EditOverlay.CanRemoveVertex = true;
    winformsMap1.EditOverlay.CanReshape = true;
    winformsMap1.EditOverlay.CanResize = true;
    winformsMap1.EditOverlay.CalculateAllControlPoints();
private void btnMisc_Click(object sender, EventArgs e)
    winformsMap1.EditOverlay.CanRotate = false;
    winformsMap1.EditOverlay.CanAddVertex = false;
    winformsMap1.EditOverlay.CanDrag = false;
    winformsMap1.EditOverlay.CanRemoveVertex = false;
    winformsMap1.EditOverlay.CanReshape = false;
    winformsMap1.EditOverlay.CanResize = false;
    winformsMap1.Refresh(); //"The given key was not present in the dictionary" error occurs here.
