Strange error with GetColumns and MsSql2008FeatureLayer
Hello again,
We have been testing our deployment package using a clean Windows 7  operating system. No software is installed except for what is installed  when the OS is installed. When we installed our project onto this  machine we noticed a strange error which was happening when we attempted  to call the following function:  MsSqlServer2008FeatureLayer.FeatureSource.GetColumns. The really funny  thing is that it does not fail when the 'Table' property of the  MsSqlServer2008FeatureLayer is a plain table, but only when you are  trying to open data from a view. The view can be something as simple as  "SELECT * FROM Table".
Here is the the error with the stack trace:
Exception Message:
Could not load file or assembly 'Microsoft.SqlServer.Types,
Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91'
or one of its dependencies. The located assembly's manifest definition
does not match the assembly reference.
(Exception from HRESULT: 0x80131040)
Exception Target Site: GetTypeByName
---- Stack Trace ----
   System.RuntimeTypeHandle.GetTypeByName(name As String, throwOnError As Boolean, ignoreCase As Boolean, reflectionOnly As Boolean, stackMark As StackCrawlMarkHandle, loadTypeFromPartialName As Boolean, type As ObjectHandleOnStack)
       GeoSuite.exe: N 00000
   System.RuntimeTypeHandle.GetTypeByName(name As String, throwOnError As Boolean, ignoreCase As Boolean, reflectionOnly As Boolean, stackMark As StackCrawlMark&, loadTypeFromPartialName As Boolean)
       GeoSuite.exe: N 00314
   System.Type.GetType(typeName As String, throwOnError As Boolean)
       GeoSuite.exe: N 00089
   System.Data.SqlClient.SqlConnection.CheckGetExtendedUDTInfo(metaData As SqlMetaDataPriv, fThrow As Boolean)
       GeoSuite.exe: N 00047
   System.Data.SqlClient.SqlDataReader.GetFieldTypeInternal(metaData As _SqlMetaData)
       GeoSuite.exe: N 6306756
   System.Data.SqlClient.SqlDataReader.GetFieldType(i As Int32)
       GeoSuite.exe: N 00155
   System.Data.ProviderBase.SchemaMapping.SetupSchemaWithoutKeyInfo(mappingAction As MissingMappingAction, schemaAction As MissingSchemaAction, gettingData As Boolean, parentChapterColumn As DataColumn, chapterValue As Object)
       GeoSuite.exe: N 6260166
   System.Data.ProviderBase.SchemaMapping..ctor(adapter As DataAdapter, dataset As DataSet, datatable As DataTable, dataReader As DataReaderContainer, keyInfo As Boolean, schemaType As SchemaType, sourceTableName As String, gettingData As Boolean, parentChapterColumn As DataColumn, parentChapterValue As Object)
       GeoSuite.exe: N 00414
   System.Data.Common.DataAdapter.FillMappingInternal(dataset As DataSet, datatable As DataTable, srcTable As String, dataReader As DataReaderContainer, schemaCount As Int32, parentChapterColumn As DataColumn, parentChapterValue As Object)
       GeoSuite.exe: N 00174
   System.Data.Common.DataAdapter.FillMapping(dataset As DataSet, datatable As DataTable, srcTable As String, dataReader As DataReaderContainer, schemaCount As Int32, parentChapterColumn As DataColumn, parentChapterValue As Object)
       GeoSuite.exe: N 00185
   System.Data.Common.DataAdapter.FillFromReader(dataset As DataSet, datatable As DataTable, srcTable As String, dataReader As DataReaderContainer, startRecord As Int32, maxRecords As Int32, parentChapterColumn As DataColumn, parentChapterValue As Object)
       GeoSuite.exe: N 00161
   System.Data.Common.DataAdapter.Fill(dataTables As DataTable[], dataReader As IDataReader, startRecord As Int32, maxRecords As Int32)
       GeoSuite.exe: N 00609
   System.Data.Common.DbDataAdapter.FillInternal(dataset As DataSet, datatables As DataTable[], startRecord As Int32, maxRecords As Int32, srcTable As String, command As IDbCommand, behavior As CommandBehavior)
       GeoSuite.exe: N 00371
   System.Data.Common.DbDataAdapter.Fill(dataTables As DataTable[], startRecord As Int32, maxRecords As Int32, command As IDbCommand, behavior As CommandBehavior)
       GeoSuite.exe: N 00504
   System.Data.Common.DbDataAdapter.Fill(dataTable As DataTable)
       GeoSuite.exe: N 00324
   ThinkGeo.MapSuite.Core.MsSql2008FeatureSource.GetColumnsCore()
       GeoSuite.exe: N 00784
   ThinkGeo.MapSuite.Core.FeatureSource.GetColumns()
       GeoSuite.exe: N 00057
   MapUtilities.CustomSQLFeatureLayer.FindDisplayField()
       CustomSQLFeatureLayer.vb: line 0295, col 07, IL 0034
   MapUtilities.FeatureSelection.FindFeaturesInSelectableLayers(oFeatureLayers As GeoCollection`1, oSelectionRect As RectangleShape, oMap As CustomWinformsMap, oSelectedFeature As Feature&)
       FeatureSelection.vb: line 0367, col 22, IL 0118
   MapUtilities.FeatureSelection.DoSelection(oMap As CustomWinformsMap, oTrackSelectionShape As BaseShape&, eSelectionType As EnumMapTool, bShowNodes As Boolean, bControlKeyDown As Boolean)
       FeatureSelection.vb: line 0174, col 13, IL 0121
   GeoSuite.frmMain.TrackOverlayTrackEnded(sender As Object, e As TrackEndedTrackInteractiveOverlayEventArgs)
       frmMain.vb: line 1791, col 16, IL 0178
   ThinkGeo.MapSuite.DesktopEdition.TrackInteractiveOverlay.JBg=()
       GeoSuite.exe: N 00560
   ThinkGeo.MapSuite.DesktopEdition.TrackInteractiveOverlay.MouseUpCore(interactionArguments As InteractionArguments)
       GeoSuite.exe: N 00160
   ThinkGeo.MapSuite.DesktopEdition.TrackInteractiveOverlay.MouseClickCore(interactionArguments As InteractionArguments)
       GeoSuite.exe: N 00169
   ThinkGeo.MapSuite.DesktopEdition.WinformsMap.ERY=(EhY= As InteractionArguments)
       GeoSuite.exe: N 00255
   8BM=.axU=.lhU=(lxU= As Object, mBU= As EventArgs)
       GeoSuite.exe: N 00132
   System.Windows.Forms.TimerNativeWindow.WndProc(m As Message&)
       GeoSuite.exe: N 00073
   System.Windows.Forms.NativeWindow.Callback(hWnd As IntPtr, msg As Int32, wparam As IntPtr, lparam As IntPtr)
       GeoSuite.exe: N 00364
  I find it interesting that it seems to be trying to load Microsoft.SqlServer.Types.dll v 10.0.0.0.  I repeat, the error does not happen if you are opening a regular table, only a view.  Here's another hint. I loaded SQL Server Express 2008R2 onto the test machine and the error went away. I then uninstalled SQL Server Express and the error came back.  I have written a small project with and install package that demonstrates the error, it's too big to attach but if you want it let me know and I will email it to you.
I get this error with both the Production and Development build.
Steve
Hi Steve,
 Sorry that we are unable to reproduce the problem, I guess the problem is in the “plain table” mentioned in your post, could try there are 2 columns "feature Id" and "Geometry" in it? Actually, we tried generating a table which has the column of Geometry, and then generate a view from it, both query in the table and view works fine, also I test on the installed and Uninstalled SQL2008 machines, everything goes well. Is it possible to give us a demo including the table schemal?issed.
Johnny,
Thanks for your reply.
The table structure is as follows:
CREATE TABLE [dbo].[State](
[DMKey] [uniqueidentifier] NOT NULL,
[StateID] [bigint] NOT NULL,
[StateName] [nvarchar](25) NULL,
[StateAbbr] [nvarchar](2) NULL,
[StateFips] [nvarchar](2) NULL,
[SurveySyst] [tinyint] NULL,
[shape] [geometry] NOT NULL,
 CONSTRAINT [PK_State] PRIMARY KEY CLUSTERED
[StateID] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
GO
ALTER TABLE [dbo].[State] ADD  CONSTRAINT [DF_State_DMKey]  DEFAULT (newid()) FOR [DMKey]
GO
ALTER TABLE [dbo].[State]  WITH NOCHECK ADD  CONSTRAINT [enforce_srid_geometry_State] CHECK  (([shape].[STSrid]=(102003)))
GO
ALTER TABLE [dbo].[State] NOCHECK CONSTRAINT [enforce_srid_geometry_State]
GO
Here is the view:
create view [dbo].[vw_States] as
select * from STATE
GO
I have also attached a simple project which I used for testing on my deplyment machine. I cannot reproduce the error on my development machine, so far I have only seen it on a clean install of Windows 7, both 32 and 64 bit. If you build the project and deploy to a target OS maybe that will help.
Thanks again for your help!
Steve
SqlServerGetColumnsTest.zip (14.2 KB)
 Hi Steven,
 Thanks for your sample, finnally i guess we find the problem, the reason is that you need to install “SQLSysClrTypes.msi”  X86 or X64 on your deployment machine.  just shown as following picture.
Here is the download link:
microsoft.com/en-us/down...x?id=26728
I have submitted this issue to our internal issue track system, we will try figure it out in near future.
Johnny,
 Thanks for the workaround. I assume that somewhere the MapSuite application still has a dependency on the 2008 r2 CLR types? Let me know when we no longer have to include them.
 Thanks again!
 Steve
Hi Steven,
 Thank you very much for the understanding, I have push it to our development team with a very high priority. Any progress I will update it here.
 Thanks again!
