Stream Loading using GdiPlusRasterLayer
This is Nadia. I am using WpfDesktopEditionFull4.5.184 and trying to load stream loading of the image. I am using the following code:
private byte[] _imageStream; //initialized with bytes
private void WpfMap_Loaded(object sender, RoutedEventArgs e)
    Map1.CurrentExtent = new RectangleShape(-155.733, 95.60, 104.42, -81.9);
    GdiPlusRasterLayer rasterLayer = new GdiPlusRasterLayer("dummy.jpg", new RectangleShape(-180, 90, 180, -90));
    ((GdiPlusRasterSource)rasterLayer.ImageSource).StreamLoading += new System.EventHandler<StreamLoadingEventArgs>(WpfMapExtended_StreamLoading_StreamLoading);
    rasterLayer.UpperThreshold = double.MaxValue;
    rasterLayer.LowerThreshold = 1;
    layerOverlay.Layers.Add(rasterLayer);
    Map1.Overlays.Add(layerOverlay);
    Map1.Refresh();
void WpfMapExtended_StreamLoading(object sender, StreamLoadingEventArgs e) {
  if (e.AlternateStreamName.Contains(".JPG") || e.AlternateStreamName.Contains(".jpg"))
     MemoryStream memoryStream = new MemoryStream(_imageStream);
     e.AlternateStream = memoryStream;
     e.AlternateStreamName = "map.jpg";
   else if (e.AlternateStreamName.Contains(".JGW") || e.AlternateStreamName.Contains(".jgw"))
      //Convert the byte[] to image so that we can get width and height.
      Image mapImage = Image.FromStream(memoryStream);
      WorldFile worldFile = new WorldFile(_fullExtend, mapImage.Width, mapImage.Height);
      StringBuilder sb = new StringBuilder();
      sb.AppendLine(worldFile.HorizontalResolution.ToString());
      sb.AppendLine(worldFile.RotationRow.ToString());
      sb.AppendLine(worldFile.RotationColumn.ToString());
      sb.AppendLine(worldFile.VerticalResolution.ToString());
      sb.AppendLine(worldFile.UpperLeftX.ToString());
      sb.AppendLine(worldFile.UpperLeftY.ToString());
      byte[] byteArray = Encoding.ASCII.GetBytes(sb.ToString());
      MemoryStream stream = new MemoryStream(byteArray);
      e.AlternateStream = stream;
      e.AlternateStreamName = "map.jgw";
 The problem is I am not getting any image. I used to get image with WpfDesktopEdition4.5 & now that I am trying to use WpfDesktopEditionFull4.5.184, the image is not there. Am i missing something?
 Nadia
Nadia,
The 4.5.184 is a daily development build and it's possible this could be a bug.  We have just released MapSuite 5.0.  If possible, I would recommend you visit helpdesk.thinkgeo.com/FullDownload and download MapSuite 5.0 and see if that fixes your problem.
If you are still having troubles after the upgrade, please reply to this post and attach your sample imagery and we will address the problem.
Phil
Hi Phil,
 I used MapSuite 5.0 & instead of checking the AlternateStreamName, i checked StreamType and it worked.
 Thanks for your help.
 regards,
 Nadia
Nadia,
 I’m glad that fixed your issue!  Thanks for posting.
