StreamLoading event - how do i know which stream is loading
Today I've been working on adding images to maps using the GdiPlusRasterLayer. As the images do not have world files associated with them, I am creating them on the fly by handling the StreamLoading event of the ImageSource. However, the StreamLoadingEventArgs does not indicate which stream is attempting to be loaded, so I am struggling trying to provide a generic event handler that allows me to dynamically load and display several images on a map.
Private _imageWorldFiles As New Dictionary(Of String, WorldFile)
Dim imageWorldFile = New WorldFile(worldExtent, imageWidth, imageHeight)
_imageWorldFiles.Add(Path, imageWorldFile)
AddHandler imageSource.StreamLoading, AddressOf MapImage_StreamLoading
Private Sub MapImage_StreamLoading(ByVal sender As Object, ByVal e As StreamLoadingEventArgs)
    If e.AlternateStreamName.Contains(".JGW") Then
        ' Need the key here or some indication of which stream we're dealing with
        Dim imageWorldFile = _imageWorldFiles("d:\_scratch\image.jpg")
        Dim sb = New StringBuilder
        sb.AppendLine(imageWorldFile.HorizontalResolution)
        sb.AppendLine("0")
        sb.AppendLine("0")
        sb.AppendLine(imageWorldFile.VerticalResolution)
        sb.AppendLine(imageWorldFile.UpperLeftX)
        sb.AppendLine(imageWorldFile.UpperLeftY)
        Dim byteArray = Encoding.ASCII.GetBytes(sb.ToString())
        Dim stream = New MemoryStream(byteArray)
        e.AlternateStream = stream
        e.AlternateStreamName = "test.jgw"
    End If
    End Sub
Here I am trying to create a WorldFile object and store them in a dictionary. Then, in the StreamLoading event, I was going to retrieve the corresponding WorldFile from the dictionary and writing it to the stream. The problem is I have no way of retrieving the key for the current stream in the event handler.
Thanks for any help you can provide. Paul
Nevermind - I think the source object is giving me the reference to the GdiPlusRasterSource that I need.
 Paul
Paul,
 I am glad you find the solution by yourself.
 When create a GdiPlusRasterLayer you will pass in the image file path, at event handler you can access e.AlternateStreamName to indicate which stream is what you want.
Thanks James. To be clear, the problem I was having is that e.AlternateStreamName doesn’t have any indication of which GdiPlusRasterSource is firing the event - but the sender object is the firing GdiPlusRasterSource, and you can pull the file name from it. The AlternateStreamName is just a delimited list of file extensions.
Paul,
 Yes, you’re right. I just think about the same event of ShapeFileFeatureSource, it will pass out the full path, but GdiPlusRasterSource doesn’t.
 Thanks for your point that.
