Street type color coding
Hello
I have been working on color coding the ma streets using diferrent colors, i downloaded a sample project  from the following link 184.73.226.83/wiki/File:Serv...100120.zip , in this shape file you use the column name CFCC from the dbf to establish local roads from highways can you show me where is the corresponding column in my shape file dbf here I sent you a rar file on your support email hope you can help me
Saddam,
  I will look at your shapefile dbf in the support email. But before doing that, I am wondering if you are using the same Riyadh shapefile as in your other posts. If this is the case, I think that the relevent column for the street types is "FUNC_CLASS". As you can see in the screen shot below, I don't know your data but this is what it seems to me.
Val
 Its the same dbf file from my other posts and ill implement the code and replay my results to you thanks again for the quike replay
 Saddam
Saddam,
  You are welcome and good luck on your development.
Val.
Val
 Its working fine thank you very much but just one question on another matter i’ve been reading on your geocoder and i believe it has soundex doe it support arabic soundex?
 Thanks alot
 Saddam
Saddam,
  Our Geocoder uses the Soundex for English. But there are Soundexes out there for other languages such a Arabic
al-shamaa.com/php/arabic...about.html
codeproject.com/Articles...ic-Soundex
ieeexplore.ieee.org/xpl/free...er=4155513
 Now I need to look at the Geocoder product and see if we expose the Soundex and how easy it would be to override it for a language other than English. Let me invistigate that and I will get back to you.
Val
 Thanks akot please let me know as as possible what you find out
 Saddam
Saddam,
   I discussed your case with a member of the Development Team about what you are trying to do with the Geocoder. You have to understand that the Geocoder was designed for geocoding US streets and although it is possible to extend it for other countries, it would require work beyond what is provided with regular Support. To have geocoding working with Riyadh data and have the Soundex adapted for Arabic, this would have to be considered Professional Services. I believe that Moritz Wolffer is your salesman. Please, contact him at moritzwolffer@thinkgeo.com for a quote on this customization work for the Geocoder. He will be very happy to guide you on that. Thank you for your interest in ThinkGeo.
Val
 I will discuss the matter with my team and ill reply any updates to you thank you very much.
 Saddam
Saddam,
  That sounds good. In the meantime, if you have any other questions, do not hesitate to use our Support such as the Discussion Forum.
Saddam,
 That sounds good. In the meantime, do not hesitate to use our Support such as this Discussion Forum for any other questions. Thank you.
Val
 I did the indexing for the streets but now im facing a problem, in which i dont have 1 layer to start the street intersection can i color the streets without havingto make them into different layers on the map and keep them as one layer so i can do the street search on it?
 Saddam
Saddam,
 I am not sure I totally understand what you are asking. I think that what you want is to display streets with the styles based on collumn value. We have the ValueStyle for that. Yoou can see example on how to use that in the sample "Draw features based on values" in the Styles category of the "How Do I" samples.  For example, for Riyadh street shapefile, you can use the "FUNC_CLASS" column and use a different style for each value. See screen shot below.
Val
 Thank you very much everyting is how i want it now thank you
 Saddam
Saddam,
  You are welcome. Good luck in your development.
