Style.DrawSample
What is the proper way to use DrawSample? I tried to simply provide it a canvas object but I get a purposeful NullException and see it is meant to be Inheritted but didn't exactly understand how.
thanks.
Nevermind, the following snippet was sufficient. I didn't realize there was a GDIPlusCanvas:
        Dim canvas As New GdiPlusGeoCanvas
        Dim areaStyle As New AreaStyle(New GeoPen(GeoColor.FromArgb(255, picAreaOutlineColor.BackColor.R, picAreaOutlineColor.BackColor.G, picAreaOutlineColor.BackColor.B), numAreaOutlineSize.Value), New GeoSolidBrush(GeoColor.FromArgb(255, picAreaFillColor.BackColor.R, picAreaFillColor.BackColor.G, picAreaFillColor.BackColor.B)))
        Dim rect As New RectangleShape(0, 6, 6, 0)
        picPreview.ImageLocation = "C:\pic.bmp"
        picPreview.Load()
        canvas.BeginDrawing(picPreview.Image, rect, GeographyUnit.Meter)
        areaStyle.DrawSample(canvas)
        canvas.EndDrawing()
Great you make it, Nelson.
I have a quick question regarding this topic. I have read in passing that not all styles will DrawSample. Admittedly, I haven't looked to far into this, but I am unable to get PointStyle.DrawSample to draw. I will see my "unlicensed" labels draw though and no error occurs. The following code determines what type of sample i'm trying to create and renders accordingly. What do I seem to be missing?
        Dim penOutline As GeoPen = Nothing
        Dim brushFill As GeoSolidBrush = Nothing
        Dim areaStyle As AreaStyle = Nothing
        Dim lineStyle As LineStyle = Nothing
        Dim pointStyle As PointStyle = Nothing
        Dim rect As New RectangleShape(0, 10, 10, 0)
        Dim colorOutline As New GeoColor(0, 0, 0, 0)
        Dim colorFill As New GeoColor(0, 0, 0, 0)
        Dim bmpPreview As New Bitmap(picPreview.Width, picPreview.Height, Imaging.PixelFormat.Format32bppArgb)
        picPreview.Image = bmpPreview
        Select Case cmbFeatureType.SelectedValue
            Case LayerConfig.FeatureTypes.Point
                If chkTransOutline.Checked = True Then
                    colorOutline = New GeoColor(picPointOutlineColor.BackColor.R, _
                                                picPointOutlineColor.BackColor.G, _
                                                picPointOutlineColor.BackColor.B)
                End If
                penOutline = New GeoPen(colorOutline, numAreaOutlineSize.Value)
                If chkTransFill.Checked = True Then
                    colorFill = New GeoColor(picPointFillColor.BackColor.R, _
                                             picPointFillColor.BackColor.G, _
                                             picPointFillColor.BackColor.B)
                Else
                    colorFill = New GeoColor(0, 0, 0, 0)
                End If
                brushFill = New GeoSolidBrush(colorFill)
'cmbPointStyle = 0, brush and pen are valid, numPointSize.value is 1D but even hard
'coding '1' does not work
                pointStyle = New PointStyle(cmbPointStyle.SelectedValue, brushFill, penOutline, CInt(numPointSize.Value))
                pointStyle.DrawSample(canvas)
            Case LayerConfig.FeatureTypes.Line
                If chkTransLine.Checked = True Then
                    colorOutline = New GeoColor(picLineColor.BackColor.R, _
                                                picLineColor.BackColor.G, _
                                                picLineColor.BackColor.B)
                End If
                penOutline = New GeoPen(colorOutline, numLineSize.Value)
                lineStyle = New LineStyle(penOutline)
                lineStyle.DrawSample(canvas)
            Case LayerConfig.FeatureTypes.Polygon
                    colorOutline = New GeoColor(picAreaOutlineColor.BackColor.R, _
                                                picAreaOutlineColor.BackColor.G, _
                End If
                    colorFill = New GeoColor(picAreaFillColor.BackColor.R, _
                                             picAreaFillColor.BackColor.G, _
                Else
                End If
                areaStyle = New AreaStyle(penOutline, brushFill)
        End Select
        canvas.EndDrawing()
It's worth noting that I can get the point styles to draw if I apply it to a FeatureLayer of any sort, so its specific to this particular scenario where I want to DrawSample a PointStyle. I noticed in Map Suite Explorer you do preview points so I am not sure that I am going about it correctly... While we're at it, what styles do not display samples? Thanks.
Nelson,
There is a known bug that the PointStyle and LineStyle’s DrawSample() doesn’t work properly. We will make it right in the next version and sorry for the inconvenience for now. Here is a relative post please have a look if you are interested.
Thank you.
You are welcome, Nelson.
