Style Serialization
Hello everyone,
For my software, I have to save the layer styles. To do that, I use the XML Serialization.
It works well with the base style (AreaStyle, LineStyle and PointStyle) but when I try to serialize a style wich contains a TextStyle (ClassBreakStyle, ValueStyle and RegexStyle), I can't do it due to the field "Dictionary<string, WorldLabelingCandidate> LabelPositions { get; }".
I really need to save the different layer styles. How can I avoid that problem ?
Thanks in advance.
Pierre,
       The Dicionary doesn’t support XML serialization, can you use BinaryFormatter instead? here is the sample code:
                        using System.Runtime.Serialization.Formatters.Binary;
                        TextStyle style = new TextStyle();
                        BinaryFormatter formatter = new BinaryFormatter();
                        MemoryStream stream = new MemoryStream();
                        formatter.Serialize(stream, style);
Thanks for your answer.
That’s my pleasure, Pierre.
