Hello, ThinkGeo Team!
I've got an interesting question. Searched among your demo, the answer is not found. As the map, you can display a multi-level road junction? For example, I have two objects that represent the road. Assume that they intersect. In one case, I may be crossing in the other - the road can be on top of each other and constitute a two-tier road interchange. I would like to find out how you can locate on the map is second situation? From the crossroads of all understandable.
Even in the simplest case. For example in cross1.png shows a conventional intersection. A in cross2.png one way over another. Due to what you can achieve similar (or even better!) display multi-level road junctions? Due to the additional attributes or coordinates, or else in some way. If you have an example, I will be grateful. Thanks in advance.
