System.ArgumentException when resizing LabelPrinterLayer
Hi guys,
I have come across a problem when using the LabelPrinterLayer. Under certain circumstances, when resizing the LabelPrinterLayer you get a System.ArgumentException with the following stack trace:
System.ArgumentException was unhandled
  Message=Value of '0' is not valid for 'emSize'. 'emSize' should be greater than 0 and less than or equal to System.Single.MaxValue.
Parameter name: emSize
  Source=System.Drawing
  ParamName=emSize
  StackTrace:
       at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
       at System.Drawing.Font.Initialize(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
       at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style)
       at ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas.Chg=(GeoFont DU8=)
       at ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas.MeasureTextCore(String text, GeoFont font)
       at ThinkGeo.MapSuite.Core.GeoCanvas.MeasureText(String text, GeoFont font)
       at ThinkGeo.MapSuite.Core.LabelPrinterLayer.ZkM=(GeoCanvas Z0M=, GeoFont aEM=, String aUM=, RectangleShape akM=)
       at ThinkGeo.MapSuite.Core.LabelPrinterLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
       at ThinkGeo.MapSuite.DesktopEdition.PrinterInteractiveOverLay.DrawCore(GeoCanvas canvas)
       at ThinkGeo.MapSuite.DesktopEdition.Overlay.kBQ=(GeoCanvas kRQ=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.NxQ=(RectangleShape FBg=, Overlay FRg=, Int32 Fhg=, Int32 Fxg=, GeographyUnit GBg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.LBQ=(IEnumerable`1 Ghg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.HBQ=()
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.GBQ=(Int32 CRg=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.BRQ=(InteractionArguments 9hc=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.8xM=(Object 6hc=, 4xU= 6xc=)
       at QRQ=.5xQ=.OnMouseEvent(4xU= e)
       at QRQ=.5xQ=.BBU=(Double BRU=, Double BhU=, Double BxU=, Double CBU=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.8Bc=(Object 8Rc=, MouseEventArgs 8hc=)
       at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseMove(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at ScaleBarTest.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
We first noticed the problem when resizing the LabelPrinterLayer by dragging one of its corners with the mouse. At a certain point when the label became quite small the exception was thrown. As usual, I have attached a sample project for your convenience.
The MapSuite Desktop version that I am using is 5.5.0.68. Note that the attached project has the same name as an earlier one I sent and does not really reflect the LabelPrinterLayer problem.
Steve
001_PositionPrinterLayer.zip (35.5 KB)
Steven,
 I have tested your sample by using  DesktopEdition.dll and MapSuiteCore.dll which version is 5.5.0.68, but I couldn’t reproduce the issue which you encountered.
 First, I click on the layer to make it to edit mode, and then drag the corner of layer boundary to make it smallest, but no exception thrown.
 If I misunderstand, please let me know and give me more information.
Hi James,
Thanks for your reply. You say you clicked on the 'layer'. Does that mean you clicked on the MapPrinterLayer or the LabelPrinterLayer? My problem is with the Label at the top of the print preview and the error occurs when it is resized, not the map.
Steve
Steven,
 Thank you for reporting this bug.  We were able to recreate the issue and it will be reviewed and assigned to our development team during the next week.  Once the bug has been resolved I will update the ticket so that you will be aware of the resolution.  If you ever need a status update, please feel free to add a comment to this ticket.
Hello Steve,
 We have fixed this problem, you can get 5.5.129.0 or later and have a try.
 Feel free to let us know if you still meet the problem.
Seems to be working fine now.
 Thanks guys.
Hello Steven,
 You are welcome.
