Hi team,
Recently I found there are some error logs in Sentry saying error keep occurring in TileView.
It happens across
Assembly:
ThinkGeo.UI.Maui Version: 14.0.0.0
ThinkGeo.UI.Maui Version: 14.5.0.0
Message : Unexpected exception in MapSource.
System.NullReferenceException: Arg_NullReferenceException
at void TileView.wUw=(object sender, PropertyChangedEventArgs e)()
at void Element.OnPropertyChanged(string propertyName)() in Element.cs:line 691
at void BindableObject.OnBindablePropertySet(BindableProperty property, object original, object value, bool didChange, bool willFirePropertyChanged)() in BindableObject.cs:line 675
at void Element.OnBindablePropertySet(BindableProperty property, object original, object value, bool changed, bool willFirePropertyChanged)() in Element.cs:line 668
at void BindableObject.SetValueActual(BindableProperty property, BindablePropertyContext context, object value, bool currentlyApplying, SetValueFlags attributes, SetterSpecificity specificity, bool silent)() in BindableObject.cs:line 663
at void BindableObject.SetValueCore(BindableProperty property, object value, SetValueFlags attributes, SetValuePrivateFlags privateAttributes, SetterSpecificity specificity)() in BindableObject.cs:line 591
at void BindableObject.SetValue(BindablePropertyKey propertyKey, object value)() in BindableObject.cs:line 511
at void Image.Microsoft.Maui.IImageSourcePart.UpdateIsLoading(bool isLoading)() in Image.cs:line 112
at async Task<IImageSourceServiceResult<UIImage>> ImageSourcePartExtensions.UpdateSourceAsync(IImageSourcePart image, UIView destinationContext, IImageSourceServiceProvider services, Action<UIImage> setImage, float imageScale, CancellationToken cancellationToken)() in ImageSourcePartExtensions.cs:line 65
at async Task ImageSourcePartLoader.UpdateImageSourceAsync()() in ImageSourcePartLoader.cs:line 76
at async Task ImageHandler.MapSourceAsync(IImageHandler handler, IImage image)() in ImageHandler.iOS.cs:line 38
at async void TaskExtensions.FireAndForget(Task task, Action<Exception> errorCallback)() in TaskExtensions.cs:line 36
Hope this help for investigation. Thank you
