System.NullReferenceException
Hello again.  I was going through my project, and stumbled upon an exception and am looking for clarification.
Here are the basics:  I am using over a dozen layers as basemaps, which are set to draw from a tile cache.  I then have about 19 other layers that aren’t cached.  I am using GoogleMaps for a base layer, which is also pulling from cached tiles.
How it crashed:  I decided to ‘play user’ and pan and zoom the map around quickly as if I were looking for something specific.  After a little bit, it gave me the System.NullReferenceException and the following stack trace.  I have also done the same thing and gotten an ObjectDisposedException.
My assumption:  I am assuming that somewhere in the ThinkGeo back end, there is a process trying to call a reference to a tile that has been changed or no longer exists.  However, I cannot fully see more information about it.
What I need to know:  I am looking for a way to somehow track down the root cause of these types of exceptions or at the very least, have a way to handle them.  Unfortunately, they do not happen in my main program so I cannot try to catch them and handle them.  Is there some manner in which I would be able to get more access to your internal error handling to avoid shut downs like this?  Basically, I am looking for a solution besides telling a user not to do something.  Telling them not to pan quickly or zoom quickly because it will crash isn’t our best option.
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass6.<DrawException>b__4()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.Run()
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at WPS_Test.Application.Main() in C:\Users\colemanb\Desktop\Rover Files\ThinkGeo_Test\PHI_Test_Projection\WPS_Test\WPS_Test\obj\x86\Debug\Application.g.vb:line 65
Hi Brandon,
Can you make sure which layer results to the crash and don’t forget to turn on the exception catch in VS? we can comment out the layers one by one to narrow down the crash reason.
In case this is an internal exception in map suite component, we can set the DrawingExceptionMode as ThrowException on each LayerOverlay to get more details of the exception and the DrawingException event also might be useful.
Hope it will help you to get more details of the crash.
