System.Resources.MissingManifestResourceException
Another exception:  This is an interesting one.  It smetimes happens when I attempt to set MapUnit.
ata : System.Collections.ListDictionaryInternal
TargetSite : System.Resources.ResourceSet InternalGetResourceSet(System.Globalization.CultureInfo, Boolean, Boolean)
Stack Trace :    at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
   at System.Resources.ResourceManager.GetString(String name, CultureInfo culture)
   at ThinkGeo.MapSuite.WpfDesktopEdition.xd092f4d605ee103f.get_xc9e96355587105e7()
   at ThinkGeo.MapSuite.WpfDesktopEdition.x547f91e235e84727.x3d738bf04b0bafd6(GeographyUnit x1ab1921c06701f43)
   at ThinkGeo.MapSuite.WpfDesktopEdition.WpfMap.set_MapUnit(GeographyUnit value)
   at EMS.ThinkGeoLibrary.Controllers.MapMasterController.OnMapInitialized(Object sender, DataEventArgs`1 e) in C:\dev\LUT600 2.1.1\OCC600\Source\GIS\Modules\ThinkGeo\ThinkGeoLibrary\Controllers\MapMasterController.cs:line 780
   at EMS.ThinkGeoLibrary.Map.Map1_Loaded(Object sender, RoutedEventArgs e) in C:\dev\LUT600 2.1.1\OCC600\Source\GIS\Modules\ThinkGeo\ThinkGeoLibrary\Controls\Map.xaml.cs:line 82
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
   at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
   at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
   at MS.Internal.LoadedOrUnloadedOperation.DoWork()
   at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
   at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.Run()
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at System.Windows.Application.Run(Window window)
   at System.Windows.Application.Run()
   at OCC600.Infrastructure.Shell.App.Main() in C:\dev\LUT600 2.1.1\OCC600\Source\Infrastructure\Infrastructure.Shell\obj\Online\App.g.cs:line 48
   at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
Hi Klaus,
 Thank you for reporting this; this is caused by encrypting some resource classes by mistake. We will rebuild it today and you can download 4.0.106.0 tomorrow to get it fix.
 Thanks again,
 Howard
Fixed, thanks.
Klaus,
 You are welcome; and thanks for reporting.
 Howard
