We handle the installation of our GIS module, and I want to be 100% sure I am installing to the correct location in regards to the System32 folder.
Do the MapSuiteGeoRasterx86, MapSuiteSpatialDataExtension, MapSuiteFdoExtensionX86 Folders go directly in the root of the System32 folder (or SysWOW64) or do they exist within a subdirectory called Map Suite 7.0?
I poked around through the sample merge modules provided, but I couldn’t quite find a good example. Do you have a recommendation for how this portion of the product should be installed?
System32 install directory
Hi Kevin,
Thanks for your post, MapSuiteSpatialDataExtension, MapSuiteFdoExtensionX86 Folders go directly in the root of the System32 folder (or SysWOW64), but in 7.0, MapSuiteGeoRasterx86 is replaced by GeoRasterx64 and GeoRasterx86 in “C:\Windows\SysWOW64\Map Suite 7.0”.
About merge modules, they are not used for your development machines, they are used to build your setup.exe for your customers. So, in your development machine you don’t need to install them.
If you have any more question , please feel free to let us know.
Best Regards
Summer
Thank you Summer.
I am aware I do not need them for my development environment. This is all in regards to our installation projects through installshield, where I include a GIS merge module. Since we are currently installing the version 5.0 DLLs with a GIS merge module, I’m trying to determine how best to make the switch to the 7.0 DLLs without having to do a major upgrade (i.e. I cannot remove merge modules/components). I just want to ensure I’m installing the non GAC files to the correct location.
Hi Kevin,
In order to ensure the corresponding merge modules are included in your upgrade, please refer to wiki.thinkgeo.com/wiki/Map_S…cies_Guide. The guide is clear to show which dlls/merge modules are responsible for the corresponding features and their locations. You can just filter the modules based on your software.
If there is any questions on this guide, don’t hesitate to let us know.
Hope it helps.
