TestLayerStyle.DrawSample
Does the TextLayerStyle.DrawSample not use the halopen even if it has been set? I have explicitly setting this but it does not show up in the sample? Sample code could be provided if this is not a known issue or can not be recreated.
Also, I am unable to get a PointStyle.DrawSample to display (but i do see the Unlicensed watermarks) but When I use the same method to draw a legend, this does work. Is this a known issue as well?
Nelson,
 I recreate that haloPen issue and confirmed it’s a bug. Thanks for pointing it out!
 That’s a known issue that PointStyle.DrawSample and LineStyle.DrawSample doesn’t work right. We have put it into our issue tracking system and hopefully it will be solved in the upcoming version.
Thank you.
You are welcome, Nelson.
