I have two problems with TextStyle objects on my InMemoryFeatureLayer.
1. Some of the text values do not get displayed until a certain zoom level. Points that are nearby each other are being hidden. However, as per the documentation, I have set the zoomlevel01 ApplyUntilZoomLevel, but it does not seem to take effect.
2. Sometimes when zooming in/out, some of the text values get partially chopped off.
Please see the screenshots for examples.
Here at zoom=8 (my default setting), some text is missing:
When user zooms in to zoom=9, the text is now shown. However, also notice my #2 issue which is the other text being chopped off.
A little background about my code. I read values from my application database and some custom calculations, and create an InMemoryFeatureLayer with a FeatureSourceColumn for my “AQI” value. The TextStyle starting at line 28 is the part which is having trouble.
As you can see I tried setting the GridSize=1… this seems to help a little, but still not all of the text values are displayed.
01.var inMemoryFeatureLayer =newInMemoryFeatureLayer();02.inMemoryFeatureLayer.FeatureSource.Open();03.// specify the AQI column for the text display04.inMemoryFeatureLayer.Columns.Add(newFeatureSourceColumn(“AQI”,“String”, 10));05.06.//Loop through all the point data from my application (_siteAqiData) and add it to the in-memory layer07.foreach(KeyValuePair<PointShape,double?> pairin_siteAqiData)08.{09.if(pair.Value.HasValue)10.{11.var feature =newFeature(pair.Key);12.feature.ColumnValues.Add(“AQI”, pair.Value.Value.ToString(CultureInfo.InvariantCulture));13.inMemoryFeatureLayer.InternalFeatures.Add(feature);14.}15.}16.//Now that all of the data is added we can build an in memory index to make the lookups fast17.inMemoryFeatureLayer.BuildIndex();18.19.if(_createPointStyle)20.{21.//Create the site point style22.PointStyle pointStyle1 = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 4,23.GeoColor.SimpleColors.Black, 2);24.inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(pointStyle1);25.}26.27.//***********NOTE******* This is the TextStyle which is having the problem28.TextStyle textStyle = TextStyles.CreateSimpleTextStyle(“AQI”,“Arial”, 12, DrawingFontStyles.Regular, GeoColor.SimpleColors.BrightBlue);29.textStyle.HaloPen =newGeoPen(GeoColor.StandardColors.White, 3);30.textStyle.PointPlacement = PointPlacement.UpperCenter;31.textStyle.YOffsetInPixel = 5;32.textStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels;33.textStyle.GridSize = 1;34.35.//Apply these styles at all levels and add then to the custom styles for the layer36.inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;37.inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(textStyle);
