The DATUM WGS 84 IS NOT Supported
Dear ALL ,
Unfortunately  The WGS Projection isn't supported by MAP Suite Desktop Edition Does anyone have any idea? and i ask the suppor team if they can impove the MAP Suite and solve this problem and thank you and good bye.
WGS84 is the most popular datum and it’s impossible we don’t support that. Just remember to set the Map.MapUnit to DecimalDegree when you display a WGS84 map. Also you can do the projection transformation by setting the property of FeatureSource.Projection, here is a sample under “Projection” ->“UseADifferentProjectionForAFeatureLayer”.
