The Feature you provided is not valid. error when trying to display shapefile
Hi, I get the following error when I try to upload the shapefile attached. It used to work before I upgraded to version 6. Can you please tell me what's wrong with it. I did some research and found that there is a MakeValid option. Can you give me an example to how this will work on my shapefile?
001_POP.zip (205 KB)
I downloaded the latest dll’s and the problem went away but the XoffsetInpixels and YoffsetInpixels in Zedgraph discussed in the link below has disappeared in the new dll.
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/39/aft/10491/afv/topic/Default.aspx
Hello Bimal,
 I’m glad it’s working, for your Zedgraph problem, if you can provide a sample to us, we can modify your code to make it work for you.
