The input double value is out of range. Parameter name: width
 I am tryng to access wpfMap Witdh and Heights using HelloWorld_WPFDesktop example, but both of them are NaN.
Any idea why it is happenning ? (I am running latest trial version)
 private void wpfMap1_CurrentScaleChanged(object sender, CurrentScaleChangedWpfMapEventArgs e)
            ZoomLevel zl = wpfMap1.ZoomLevelSet.GetZoomLevel(wpfMap1.CurrentExtent, wpfMap1.Width, wpfMap1.MapUnit);
Hello Michael,
 Thanks for your post, do you modify anything of that sample? Is that possible you can upload it here?
 Hi Gary,
I only upgraded it to VS2010 and added wpfMap1_CurrentScaleChanged handler.
Plese, look onto attached zip.
Thank you,
Michael
HelloWorld_WPFDesktopZoom.zip (32.1 KB)
 Hello Michael,
 The reason is you are using wpfMap1_CurrentScaleChanged, and in this time, the map does not totally initialized, so you can't get Width and Height.
 You can try:
void wpfMap1_CurrentExtentChanged(object sender, CurrentExtentChangedWpfMapEventArgs e)
 Let us know your queries.
 Hi Gary,
Unfortunately that change did not helped - same error.
Howewer, all working when I am using  wpfMap1.ActualWidth
Any idea  why ?
Thank you,
Michael
Hello Machael,
 Sorry I made a mistake to paste the code, please use e.MapWidth instead of wpfMap1.Width, the reason is like I said above, the map control does not totally initiative.
