I added the following lines of code to a controller class that manages my map instances so that I can change base map from WorldMapKit to OpenStreetMaps, Google or Bing.
var featureLayers = map.GetFeatureLayers();var proj4Projection =newManagedProj4Projection();proj4Projection.InternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(4326);proj4Projection.ExternalProjectionParametersString = ManagedProj4Projection.GetGoogleMapParametersString();
foreach(var featureLayerinfeatureLayers){featureLayer.FeatureSource.Projection = proj4Projection;}map.SafelyRefresh();
When I run the application, I now get error: “The projection is not open. Please open it before calling this method”. I am not explicitly calling FeatureSource.Open any where in these feature layers so do not know the proper way to correct this.
Based on a similar problem reported here, I tried creating a projection object for each layer and this still fails with the aforementioned error.
var featureLayers = map.GetFeatureLayers();foreach(var featureLayerinfeatureLayers){var proj4Projection =newManagedProj4Projection();var srid = ViewState.ProjectionSRID;proj4Projection.InternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(srid);proj4Projection.ExternalProjectionParametersString = ManagedProj4Projection.GetGoogleMapParametersString();
How do I handle this?
Klaus
