The record is invalid, please call Validate
At random times, I get the following exception:
The record is invalid, please call Validate method to check the failed reason.Record index: 39
This occurs at random times, and doesn't even occur all the time for the same zoom level/extent (it is occuring on getfeaturesinsideboundingbox.  If I call validate, I get 0 results.  Any help would be appreciated as to why this is exploding.
As a side note, I have multiple threads potentially hitting this shapefile, so maybe that has something to do with it?
.Ryan.
Hello Ryan,
 Thanks for your post, could you give me more information to recreate this problem? What’s your scenario? And if it’s possible you can provide a self-contained sample, that will helps a lot.
