The specified input does not represent a valid geography
I have trouble with some shapes and inserting into a SQL server table with a geography field defined.
It tells me "The specified input does not represent a valid geography instance".  I know I can get around this by also having a geometry field defined and use that and SQL server to clean up the object before updating the geography field .
Is there any way to clean up the ring orientation, intersecting lines of a polygon, ect.. without pushing the feature to SQL Server and performing the cleaning there?  I tried to see if there was a MakeValid method on the shape or the feature and there doesn't seem to be.  I would rather take care of cleaning the shape client side than server side if I can.
Example of code where newFeature has invalid geometry.
sql2008Layer.EditTools.BeginTransaction();
sql2008Layer.FeatureSource.AddFeature(newFeature);
TransactionResult result = sql2008Layer.EditTools.CommitTransaction();
In case anyone is interested, this is how I solved my issue.  I have it in my c# code now but I will be moving it to a stored procedure where I can pass in WKT and get back WKT that is clean and ready to be used in a geography field.  I also included a sample of how I check to see if my shape is valid for a geography or not. (SQL 2008)
 Sample of clean:
  workingVersion = SqlGeometry.STGeomFromWKB(new SqlBytes(inputFeature.GetWellKnownBinary()), 4326);
   finalVersion = SqlGeography.STGeomFromWKB(workingVersion.MakeValid().STUnion(workingVersion.MakeValid().STStartPoint()).Reduce(0.00001).STAsBinary(), 4326 );
  outputFeature = new Feature(finalVersion.STAsText().ToSqlString().ToString(), inputFeature.Id, inputFeature.ColumnValues);
 Sample of check:
 bool isShapeValid = false;
             try
                 SqlGeography testCopy = new SqlGeography();
                 testCopy = SqlGeography.STGeomFromText(new SqlChars(WKT.ToCharArray()), 4326);
                 isShapeValid = true;
             catch (Exception e)
Peter,
Thanks for your posts and sharing. I even did not work it out via many tests; you are more familiar than me in SQL:).
