The Use of Proj4 in map areas with different Projection datums
Hi Tsui,
  Proj4.InternalProjectionParameterString and .ExternalProjectionParameterString are used together to define a Mercator Transformation with Projection Datum information. For map areas with different Projection Datums, how am I going to ensure that the Mercator Transformation is defined with proper Projection Datum info at the corresponding area so that the Mercator transformation can be done effectively to convert a map point in local coordinates into its Latitude and longitude counterpart? In other words, how am I going to define the Transformation properly at all the map areas of interest with appropriate Projection Datum informations?
Franklin
 We have a Code Community sample that explain about datum transformation while in Geodetic. The sample shows how to go from ED50 to WGS84. The sample is called Datum Transformation wiki.thinkgeo.com/wiki/Map_Suite_De...sformation
 Now, for your specific case, I would need a little bit information from you. I am a little confused about what kind of scenario you are dealing with.
