This.layer.renderer
hello
I ask for excuses and I hope that understand me,  because my ingles not is very good and is my first time what write in discussion foruns
I have a problem when create a circular Shape
I have a javaScript function that is executed when client drawn end, this function it works well when create a poligonal shape, but generates an error when shape is circular or rectangular.
the error generated is ''this.layer.renderer' is null or not an object' in opl_Georesorce.axd.
the code of the function that generate this error is:
var TrackShapeFinished = function(feature) {
        var GeoFunc = new ThinkGeo('');
        var Mode = document.getElementById('').value;
        if (Mode == '' || Mode == '' || Mode == '' || Mode == '') {
            GeoFunc.SetEditSetting(EditSettings.Reshape | EditSettings.Rotate | EditSettings.Drag);
            if (Mode == '' || Mode == '') {
                GeoFunc.SetEditSetting(EditSettings.Resize | EditSettings.Drag);
        GeoFunc.SetDrawMode("Modify");
I work with version 3.1.299.0 the map
in advance thank you very much
Hi Diego,
Please refer to the following post for detail:
Howard
