TIFFwith World File no Showing
I am loading a TIFF using the following code, but the image does not appear.  Is there something wrong (maybe with the World File?  I downloaded the image from TerraServer and it came with the World File.
    Private Sub AddRasterImage(ByVal filePath As String, ByVal OverlayKey As String)
        Dim worldImageLayer As GdiPlusRasterLayer = New GdiPlusRasterLayer(filePath)
        AddHandler (CType(worldImageLayer.ImageSource, GdiPlusRasterSource)).StreamLoading, AddressOf Image_StreamLoading
        worldImageLayer.UpperThreshold = Double.MaxValue
        worldImageLayer.LowerThreshold = 0
        worldImageLayer.IsGrayscale = False
        Dim ImageOverlay As LayerOverlay = New LayerOverlay()
        ImageOverlay.Layers.Add(OverlayKey & "Layer", worldImageLayer)
        WpfMap1.Overlays.Add(OverlayKey & "Overlay", ImageOverlay)
        WpfMap1.Overlays.MoveToBottom(WpfMap1.Overlays.IndexOf(ImageOverlay))
    End Sub
    Private Sub Image_StreamLoading(ByVal sender As Object, ByVal e As StreamLoadingEventArgs)
        If e.StreamType = "Image File" Then
            Dim stream As IO.Stream = New FileStream(e.AlternateStreamName, FileMode.Open, FileAccess.Read)
            e.AlternateStream = stream
        End If
        If e.StreamType = "World File" Then
            Dim fName As String = IO.Path.GetFullPath(e.AlternateStreamName)
            Select Case IO.Path.GetExtension(e.AlternateStreamName).ToUpper
                Case ".TIF"
                    fName = fName.Substring(0, fName.Length - 3) & "tfw"
                Case ".JPG"
                    fName = fName.Substring(0, fName.Length - 3) & "jgw"
            End Select
            Dim stream As IO.Stream = New FileStream(fName, FileMode.Open, FileAccess.Read)
        End If
    End Sub
The World File contains:
5.648000
0.000000
0.000000
-5.648000
573645.000000
2918226.000000
If I use:
        Dim worldImageLayer As GdiPlusRasterLayer = New GdiPlusRasterLayer(filePath, New RectangleShape(-80.26173, 26.38224, -80.1914, 26.31811))
without streaming, then the image shows up
Hello Michael,
 Thank you for your post.
 I think the key is e.AlternateStream = stream, this is the only different with or without steaming.
 Can you debug this part and compare the difference ?
If I put a debug.print statement before both e.AlternateStream = stream in the streamloading method, I get alternating world file and image file, but still no image on the map.  If I zoom in or out, I still see the alternating streaming.
Could it be the different projectons in the world file?  For instance, one of my worlld files is:
 Geo-reference Information:
 Projection: Geographic
 Datum: WGS 84
 Image Units: Meters
 and the oher is:
 Projection: UTM Zone 17
 Datum: WGS 84
 Image Units: Meters
Michael,
  Let me interject in the conversation very quick. I am not familiar with the streaming issue but one thing that you need to make sure is to set the MapUnit of your map correctly. If you world file contains values like 573645 for the x-coordinate of the center of the upper left pixel and 2918226 for the y-coordinate, then the MapUnit has to be in Meters. The world file itself does not contain projection information, only the coordinates for the image to be placed geographically. (en.wikipedia.org/wiki/World_file) . I just want to make sure we have that well established before trying to find the problem anywhere else.
Good catch… that is probably the problem.  Now the question is, is there a way to use a world file in meters when the map is set as DecimalDegree?  Or do I just have to plan on putting the rectangle in?
Michael,
 No, if your image is in meters, you need to have your map unit also in that unit. Only in some specific situations you can trick an image into Decimal Degrees from Meters. I suggest you look at the sample code Google Map to Geodetic  so that you get a little more background on the issue. wiki.thinkgeo.com/wiki/Map_Suite_De...o_Geodetic
 For your question "Do I just have to plan on putting the rectangle in?". I am not sure what you mean.
Micheal,
 As the Val said, the image’s unit should be the same as the map unit and I think the sample project is useful for you.
 For your question “Do I just have to plan on putting the rectangle in”, I guessed you talked about the extent for the map, if that, you should set the map’s current extent to the boundingbox of the image to display it.
 Scott,
Thanks Scott and Val.  What I meant by the rectangle is that I will not use the world file, but instead just display the image using:
Micheal,
 Thanks for your explanations!
 Yes, if you have the correct extent value for the image file, you don’t need to use the world file. But you need to set the extent correctly so that the image file display correctly.
 Any more questions please let me know,
 Scott,
