I’m loading a topo map as a png file in a GdiPlusRasterLayer. I then apply tile caching using the following code:
IEnumerable<string> fileNames = Directory.EnumerateFiles(@“O:\GIS Data\Gothics", “*.png”);// replace this with proper db callmapUnit = GeographyUnit.Meter;
RectangleShape rect =null;
foreach(stringfileNameinfileNames)// there’s only 1 at the moment{GdiPlusRasterLayer rasterLayer =newGdiPlusRasterLayer(fileName);//I’m using a GdiPlusRasterLayer instead of a GeoTiffRasterLayer because it renders nicer (go figure)rasterLayer.UpperThreshold =double.MaxValue;rasterLayer.LowerThreshold = 0;
//get the bounding box of the area we’re loading so we can restrict the map to that arearasterLayer.Open();if(rect ==null)rect = rasterLayer.GetBoundingBox();elserect = rect.Union(rasterLayer.GetBoundingBox()).GetBoundingBox();
rasterLayer.Close();
staticOverlay.Layers.Add(rasterLayer);}
loadedArea = rect;
MapControl.MapUnit = mapUnit;//set the units on the map according to the map’s spatial reference indexMapControl.CurrentExtent = loadedArea;// this doesn’t set the CurrentExtent to the exact loadedAreaMapControl.RestrictExtent = loadedArea;//restrict the map’s ability to scroll beyond the loaded map areaMapControl.MinimumScale = MapControl.ZoomLevelSet.ZoomLevel15.Scale;MapControl.MaximumScale = MapControl.ZoomLevelSet.ZoomLevel12.Scale; /
//setup tile cachingFileBitmapTileCache topoTileCache = new FileBitmapTileCache();topoTileCache.CacheDirectory = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) + @”\Snowbase2\TileCache";topoTileCache.CacheId = “BaseMapCache”;topoTileCache.ImageFormat = TileImageFormat.Png;
staticOverlay.TileCache = topoTileCache;staticOverlay.TransitionEffect = TransitionEffect.None;
//add the static overlay to the mapMapControl.Overlays.Add(“staticOverlay”, staticOverlay);
This behaves as expected and generates tiles as I zoom and pan around the map. Next I wanted to pre-generate the tiles using the CacheGenerator app. In the CacheGenerator’s LayerProvider, I changed the GetLayersToCache() method to:
public static Collection<Layer> GetLayersToCache(){Collection<Layer> layersToCache = new Collection<Layer>();
GdiPlusRasterLayer layer = new GdiPlusRasterLayer(@“O:\GIS Data\Gothics\GO_SB2_TOPO_WMS_DRAFT_500dpi.png”);
layersToCache.Add(layer);
return layersToCache;}
and then, instead of using the Top Left Point/Bottom Right Point text fields, I call
tileCacheGenerator.CachingExtent = LayerProvider.GetImageBoundingBox();
which is a method I wrote with the following implementation
public static RectangleShape GetImageBoundingBox(){RectangleShape rect = null;foreach (Layer layer in layersToCache){layer.Open();if (rect == null)rect = layer.GetBoundingBox();elserect = rect.Union(layer.GetBoundingBox()).GetBoundingBox();layer.Close();}
return rect;}
I also set the Map Units to Metres in the CacheGenerator, as I did with my app.
The final result is that the tileCacheGenerator.CachingExtent property is equal to the bounding box of the PNG file I’m loading. However, when I try to use the tiles generated by the CacheGenerator, my application instead generates it’s own tiles which are slightly offset from the ones generated by the CacheGenerator (see image attachment). The directory structure is also named differently so I’m guessing that they are starting at different coodinates. Does this have to do with the fact that the mapControl’s CurrentExtent isn’t exactly equal to my PNG’s bounding box? If so, what’s going on in the MapControl.CurrentExtent setter that changes the value I assign to it? What do I need to do to fix this?
Trevor
