To find latitude and longitude using GetBoundingBoxById
 I selected one street name from Combobox, then proper street is coming to the winform map(ie. SelectedPOILayer.FeatureSource.GetBoundingBoxById(POI.SelectedValue.ToString());.  I need Selected Street Name should be highlighted in the Map using Marker and how to get latitude and longitude also.
 private void POI_SelectedIndexChanged(object sender, EventArgs e)
            if (POI.SelectedValue.ToString() == "System.Data.DataRowView")
                return;
            if (POI.SelectedValue.ToString() == "-1" || POI.SelectedValue == null)
                return;
            ShapeFileFeatureLayer SelectedPOILayer = new ShapeFileFeatureLayer(@"C:\Program Files\ThinkGeo\Map Suite Desktop Evaluation Edition 5.0\Samples\SampleData\Data\RIYADH_POI.shp");
            SelectedPOILayer.Open();
            winformsMap2.CurrentExtent = SelectedPOILayer.FeatureSource.GetBoundingBoxById(POI.SelectedValue.ToString());
            winformsMap2.CurrentExtent.ScaleUp(300);
             winformsMap2.MapClick += new EventHandler<MapClickWinformsMapEventArgs>(winformsMap2_MapClick);
            staticOverlay.Layers.Add("SelectedPOILayer", SelectedPOILayer);
            winformsMap2.Overlays.Add(staticOverlay);
            SelectedPOILayer.Close();
            winformsMap2.Refresh();
Hello yakub,
We have a easy way to do the highlight job in the map, named HighlightOverlay, here is a sample can show you how it works, and in this sample, HighlightOverlay_Click function, you can get the e.Location, this is the latitude and longitude you want, if you are in right projection.
HoverTheFeature.zip (214 KB)
