Topology Exception
I am getting the below exception when running a GetFeaturesNearestTo query on multiPolygon type layers.  I am guessing it has something to do with the NaN value in the z coordinate.
Here’s the function I am using:
 Collection<Feature> selectedFeature = imfl.QueryTools.GetFeaturesNearestTo(clickedPoint, GeographyUnit.Meter, 1, new string[1] { “Name” }, 250, DistanceUnit.Meter);
GisSharpBlog.NetTopologySuite.Geometries.TopologyException was unhandled
  Message=side location conflict [ (12720485.1419011, 542540.041027168, NaN) ]
  Source=NetTopologySuite
  StackTrace:
       at GisSharpBlog.NetTopologySuite.GeometriesGraph.EdgeEndStar.PropagateSideLabels(Int32 geomIndex)
       at GisSharpBlog.NetTopologySuite.GeometriesGraph.EdgeEndStar.ComputeLabelling(GeometryGraph[] geom)
       at GisSharpBlog.NetTopologySuite.Operation.Relate.RelateComputer.LabelNodeEdges()
       at GisSharpBlog.NetTopologySuite.Operation.Relate.RelateComputer.ComputeIM()
       at GisSharpBlog.NetTopologySuite.Operation.Relate.RelateOp.get_IntersectionMatrix()
       at GisSharpBlog.NetTopologySuite.Operation.Relate.RelateOp.Relate(IGeometry a, IGeometry b)
       at GisSharpBlog.NetTopologySuite.Geometries.Geometry.Relate(IGeometry g)
       at GisSharpBlog.NetTopologySuite.Geometries.Geometry.Intersects(IGeometry g)
       at ThinkGeo.MapSuite.Core.BaseShape.IntersectsCore(BaseShape targetShape)
       at ThinkGeo.MapSuite.Core.BaseShape.Intersects(BaseShape targetShape)
       at ThinkGeo.MapSuite.Core.MultipolygonShape.GetDistanceToCore(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.BaseShape.GetDistanceTo(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit)
       at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesWithinDistanceOfCore(BaseShape targetShape, GeographyUnit unitOfData, DistanceUnit distanceUnit, Double distance, IEnumerable`1 returningColumnNames)
       at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesWithinDistanceOf(BaseShape targetShape, GeographyUnit unitOfData, DistanceUnit distanceUnit, Double distance, IEnumerable`1 returningColumnNames)
       at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesNearestTo(BaseShape targetShape, GeographyUnit unitOfData, Int32 maxItemsToFind, IEnumerable`1 returningColumnNames, Double searchRadius, DistanceUnit unitOfSearchRadius)
       at ThinkGeo.MapSuite.Core.QueryTools.GetFeaturesNearestTo(BaseShape targetShape, GeographyUnit unitOfData, Int32 maxItemsToFind, IEnumerable`1 returningColumnNames, Double searchRadius, DistanceUnit unitOfSearchRadius)
       at EmuSL.SelectObjectsOnMap.SelectItemOnMap(WinformsMap winformsMap, TreeList treeLayers, LayerOverlay layerOverlay, BaseShape clickedPoint, Int32 scenarioID) in C:\Users\dhite\Documents\Visual Studio 2010\Projects\EMU\EmuSL\SelectObjectsOnMap.cs:line 56
       at EmuSL.Main.winformsMap1_MapClick(Object sender, MapClickWinformsMapEventArgs e) in C:\Users\dhite\Documents\Visual Studio 2010\Projects\EMU\EmuSL\Main.cs:line 1498
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.OnMapClick(MapClickWinformsMapEventArgs e)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.DBQ=(InteractionArguments yBc=)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.8xM=(Object thc=, 4RU= txc=)
       at QRQ=.2xQ=.OnMouseEvent(4RU= e)
       at QRQ=.2xQ=.CRU=(Object ChU=, EventArgs CxU=)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at EMU.Program.Main() in C:\Users\dhite\Documents\Visual Studio 2010\Projects\EMU\EMU\Program.cs:line 18
  InnerException:
Nevermind.  I have just seen the excellent project on merging these shapes and that has worked perfectly.
 Damian
Hi Damian,
Glad to hear you have got a way to fix the issue. Actually,
here is a similar thread in our forums thinkgeo.com/forums/MapSuite...fault.aspx
, we can see it seems there are some bugs in NetTopologySuite validations on
some spatial shapes.
Thanks for your post anyway.
