Hi Tsui,
I am trying 'remove InTrackingFeature' method to fix the "shade doesn't fade away" problem when clicking the btnTrackPoint from position 1 to position 2 on a map. But the method doesn't seem working. I checked the Sample C# application for Map Suite 4.5 at node
Editing Feature Layer, subnode: Track and Edit Shapes. If you click the "point" button, you will find the same issue is there.
Do you know how to remove the "dot" image remained at position 1 after clicking at position 2?
Franklin
