TrackOverlay.TrackEnded Event Firing twice
I am drawing a rectangle to create a bounding box to zoom in to using the TrackOverlay.  I have noticed that on occasion, the event fires twice, and I am wondering if it is possibly a bug or a mishap on my code that causes this.  I use two Subs to zoom into an area but the AreaZoomTrackEnded sub fires twice on occasion.
I have since added a check for the InternalFeatures of the TrackShapeLayer before continuing to prevent an IndexOutOfRangeException.  I would think that removing the handler and turning off the TrackMode would stop it from somehow trying to fire TrackEnded again.  If there is something differently that should be done, let me know.
Private Sub ZoomToArea(ByVal sender As Object, ByVal e As RoutedEventArgs) Handles tbAreaZoomTo.Click
        DirectCast(sender, ToggleButton).IsChecked = False
        'add handler for trackoverlay ended
        AddHandler WpfMap_Main.TrackOverlay.TrackEnded, AddressOf AreaZoomTrackEnded
        'change the track settings // display and style
        WpfMap_Main.TrackOverlay.TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.StandardColors.Transparent, GeoColor.StandardColors.Red, 2, LineDashStyle.Dash)
        WpfMap_Main.TrackOverlay.TrackMode = TrackMode.Rectangle
    End Sub
    Private Sub AreaZoomTrackEnded(ByVal sender As Object, ByVal e As TrackEndedTrackInteractiveOverlayEventArgs)
        'check for features in the trackshapelayer, if there are no features, exit the sub and allow for continued drawing
        If WpfMap_Main.TrackOverlay.TrackShapeLayer.InternalFeatures.Count = 0 Then
            Exit Sub
        End If
        'remove handler
        RemoveHandler WpfMap_Main.TrackOverlay.TrackEnded, AddressOf AreaZoomTrackEnded
        'turn off trackmode
        WpfMap_Main.TrackOverlay.TrackMode = TrackMode.None
        'get the shape
        Dim trackPoly As PolygonShape = DirectCast(WpfMap_Main.TrackOverlay.TrackShapeLayer.InternalFeatures(0).GetShape, PolygonShape)
        'clear the track shapes
        WpfMap_Main.TrackOverlay.TrackShapeLayer.InternalFeatures.Clear()
        'set the new extent
        WpfMap_Main.CurrentExtent = trackPoly.GetBoundingBox
        'refresh the map
        WpfMap_Main.Refresh()
    End Sub
Hi Brandon,
 I haven’t reproduced your problem.
 I move your code into a sample of our HowDoISamples, then comment the code:
 'If wpfMap1.TrackOverlay.TrackShapeLayer.InternalFeatures.Count = 0 Then
         ’    Exit Sub
         'End If
 And when I track end, the AreaZoomTrackEnded only be fired once. My test code is our latest version.
 Please let me know if I miss any step for reproduce that.
