Translate code from another version - Help needed
HI,
  What I am wanting to define a set of points and display all points in a map at the proper zoom level.  I found this code, but some of the classes do not resolve.  Could someone help out with this transaltion, or suggest a better way?
private RectangleR CalculateMapExtent()
    //Declare Variables
    PointShape pointShape;
    double upperLeftLat = 0;
    double upperLeftLong = 0;
    double lowerRightLat = 0;
    double lowerRightLong = 0;
    //Loop through the points collection to find the upper left and lower right point values
    foreach (BaseMapShape baseMapShape in Map1.MapShapes)
        if (baseMapShape is PointMapShape)
            pointShape = (PointShape)baseMapShape.BaseShape;
            if (pointShape.Y > upperLeftLat | upperLeftLat == 0) upperLeftLat = pointShape.Y;
            if (pointShape.X < upperLeftLong | upperLeftLong == 0) upperLeftLong = pointShape.X;
            if (pointShape.Y < lowerRightLat | lowerRightLat == 0) lowerRightLat = pointShape.Y;
            if (pointShape.X > lowerRightLong | lowerRightLong == 0) lowerRightLong = pointShape.X;
    //Create variables to set the extent
    PointR upperLeftPoint = new PointR(upperLeftLong, upperLeftLat);
    PointR lowerRightPoint = new PointR(lowerRightLong, lowerRightLat);
    RectangleR mapExtent = new RectangleR(upperLeftPoint, lowerRightPoint);
    //Scale Up Map extent by 5%
    mapExtent.ScaleUp(5);
    if (mapExtent.get_Width(MapLengthUnits.DecimalDegrees, MapLengthUnits.miles) < 400)
        while (!(mapExtent.get_Width(MapLengthUnits.DecimalDegrees, MapLengthUnits.miles) > 400))
    return mapExtent;
Hi Steve,
This is the code from 2.0; in 3.0 we get rid of some of the old API and have some good API instead.
In this code, we removed the MapShapes collection; instead, we use InMemoryFeatureLayer instead to maintain these shapes. So let's change the requirement of this code a little: To find an extent to include all the shapes which you passed in from the parameter. The code is quite simple.
private RectangleShape CalculateMapExtent(Collection<Feature> features)
    RectangleShape returnExtent = new RectangleShape();
        returnExtent.ExpandToInclude(feature);
    returnExtent.ScaleUp(5);
    return returnExtent;
Howard
Howard,
   Your code works, just not as I expected.  Please look at my code and modify.
     public partial class PlotAPoint : System.Web.UI.Page
             if (!Page.IsPostBack)
                 Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"));
                 Map1.CurrentExtent = new RectangleShape(-88.1422, 42.4009, -87.5169, 41.4529);
                 Map1.MapTools.PanZoom.Enabled = true;
                 Map1.MapTools.PanZoomBar.Enabled = false;
                 ShapeFileFeatureLayer defaultLayer = new ShapeFileFeatureLayer(Server.MapPath("~/Map/ILlkA.shp"));
                 defaultLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(LineStyles.LocalRoad1);
                 defaultLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 Map1.StaticOverlay.Layers.Add(defaultLayer);
                 // The following two lines of code enable the client and server caching.
                 // If you enable these features it will greatly increase the scalability of your
                 // mapping application however there some side effects that may be counter intuitive.
                 // Please read the white paper on web caching or the documentation regarding these methods.
                 Map1.StaticOverlay.ClientCache.CacheId = "defaultOverlay";
                 Map1.StaticOverlay.ServerCache.CacheDirectory = MapPath("~/ImageCache/" + Request.Path);
                 InMemoryFeatureLayer shapeLayer = new InMemoryFeatureLayer();
                 shapeLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle =
                     PointStyles.CreateSimplePointStyle(PointSymbolType.Circle, GeoColor.StandardColors.Green, 3);
                 shapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                 Map1.DynamicOverlay.Layers.Add("pointShapeLayer", shapeLayer);
                 Feature pointFeature = new Feature(new PointShape(
                     double.Parse("-87.8225020", CultureInfo.InvariantCulture), double.Parse("42.3754010", CultureInfo.InvariantCulture)));
                 shapeLayer.InternalFeatures.Add(pointFeature.Id, pointFeature);
                     double.Parse("-88.08842", CultureInfo.InvariantCulture), double.Parse("42.19746", CultureInfo.InvariantCulture)));
                     double.Parse("-88.063", CultureInfo.InvariantCulture), double.Parse("42.21907", CultureInfo.InvariantCulture)));
                 Map1.CurrentExtent = CalculateMapExtent(shapeLayer.InternalFeatures);
                 Map1.DynamicOverlay.Redraw();
   Steven
Steven,
The method I pasted above is a generic method; it'll be much more easier to find the extent from a FeatureLayer.
You can get rid of the CalculateMapExtent method and Map1.DynamicOverlay.Redraw(); use the following script instead:
shapeLayer.Open();
Map1.CurrentExtent = shapeLayer.GetBoundingBox();
shapeLayer.Close();
If you have any questions please let me know.
Howard
Howard,
   Exellent, thank you very much.
 Steven
Steven,
You are welcome; if you have any queries, please let me know.
Howard
