Translate Spherical Point by bearing and distance
My code leverages a very old .Net component that I'd like to replace with MapSuite code.  I have a VB.Net Function that accepts a lat/lon point, a bearing (direction) in degrees, and a distance in meters and returns a lat/lon point that is translated from the input point by the distance specified in the direction specified by the bearing (as shown below).  Are there similar routines available in MapSuite that can accomplish the same thing?
'Calculate lat/lon position from a start position to distance (in meters) away at a specified bearing
'Return lat/lon as a ThinkGeo Pointshape
Public Function TranslatePoint(ByVal point1LatDMS As Double, ByVal point1LonDMS As Double, ByVal bearing As Single, ByVal distanceMeters As Single) As PointShape
'setup position points:
Dim point1 As New Position(New GeoFramework.Longitude(point1LonDMS), New GeoFramework.Latitude(point1LatDMS))'Finally, make the calculation of intercept point
Dim translatedPoint As Position
translatedPoint = point1.TranslateTo(
New GeoFramework.Angle(bearing), New GeoFramework.Distance(distanceMeters, GeoFramework.DistanceUnit.Meters))'Convert to ThinkGeo PointShape type and return
Dim newPoint As New PointShape(translatedPoint.Longitude.DecimalDegrees, translatedPoint.Latitude.DecimalDegrees)Return newPointEnd Function
Michael,
 Thanks for using the MapSuite, there is an easy way to accomplish your request.
We have a method in PointShape called TranslateByDegree, you can try this, and please look at the code below:
        Dim ps As New PointShape(point1LatDMS, point1LonDMS)
        ps.TranslateByDegree(distanceMeters, bearing, GeographyUnit.DecimalDegree, DistanceUnit.Meter)
        Return ps
    End Function
Let me know if you have any questions.
Fantastic - works great.  Appreciate the quick reply.
Michael,
  I am glad we found a quick solution for you. Also, I let you know that we have numerous samples related to degrees, lat/long issues etc. Do not hesitate to take advantage of that resource wiki.thinkgeo.com/wiki/Map_Suite_De...ll_Samples
Good stuff…thanks again.
Val,
 Thanks for your sharing.
