Traveling Salesman Problem based on Time not Distance
I have a bit more of a complex traveling salesman question for you. My service picks up clients to be transported to different appointments. These people must be picked up at a certain time and delivered at a certain time. We are attempting to develop an application that can create a route based on these schedules that allow to pick up and deliver as many people a quickly as possible.
Do you have any samples that can demonstrate how to set this kind of route?
R,
To make sure we are standing on the same line, let me descript my understanding at first:
There are several places needed to visit marked with P(p1, p2 … pn), the corresponding visit time array is T( t1, t2 … tn ) , and the start visiting time is t0, start place is p0. The constraint is the visit time for each client should be earlier than needed visit time (tn). We need to create a route base on the schedule. Right?
I’m sorry but I need to say we can’t solve it based on lasted public release if the description is what you want, which is a Vehicle Routing Problem (VRP). However, we can give you a temporary version by asking for support@thinkgeo.com if you want it, maybe a little slower, but we will solve it as soon as possible if you are urgent.
Here are some tips about how to deal with that based on the temporary version:
1. Build routing index file using driving time (Minutes) as the weight of RouteSegment.
2. Initialize a matrix containing all the RoutingResult between places, and below is the sample code:
List<PointShape> points = new List<PointShape>(P);
      points.Add(p0);
      // Initialize Route Matrix
      RoutingResult[,] routeMatrix = new RoutingResult[points.Count, points.Count];
      for (int i = 0; i < points.Count; i++)
            for (int j = i + 1; j < points.Count; j++)
               RoutingResult result = GetRoute(points[i], points[j]); // Get the route between two places
               if (result.RouteSegments.Count <= 0)
                   result.Distance = double.MaxValue;
               routeMatrix[i, j] = result;
               routeMatrix[j, i] = result;
3. Use “routingEngine.GetRouteViaVisitStops” to create the route, and attach the “GettingRouteViaVisitStops” event to RoutingEngine. See sample code below:
      routingEngine.GettingRouteViaVisitStops += new EventHandler<GettingRouteViaVisitStopsRoutingEngineEventArgs>(routingEngine_GettingRouteViaVisitStops);
      routingEngine.GetRouteViaVisitStops(p0, points, 100);
4. Filter the temporary visit route in “routingEngine_GettingRouteViaVisitStops” method.
Collection<int> visitIndexes = e.VisitSequence;
            DateTime visitTime = new DateTime();
            int startIndex = points.Count;
            for (int i = 0; i < visitIndexes.Count; i++)
                int visitIndex = visitIndexes<i>;
                // Get the time between two places
                double time = routeMatrix[startIndex, visitIndex].Distance;
                visitTime.AddMinutes(time);
                double requiredVisitTime = T[visitIndex];
                if (visitTime.CompareTo(requiredVisitTime) > 0) // the visit time is later than the required
                    e.TotalDistance = Double.MaxValue;
  e.VisitSequence.clear();
                    break;
Thanks for your ideas, which did help improving our products a lot. This is a bit more complex, and any question please let me know.
Hi I Am getting an exception
 "The parameter you supplied may not be null.
 Parameter name: featureSource"
 while executing the following code
  ThinkGeo.MapSuite.Routing.RoutingEngine routingEngine = new ThinkGeo.MapSuite.Routing.RoutingEngine();
                 double distance = routingEngine.GetRoute(new PointShape(startLongitude, startLatitude),
        new PointShape( endLongitude,endLatitude)).Distance;
 please help!
govind,
 Thank you for your post, could you please provide a sample or a stack-trace?
