Trouble with Transparency
I am Creating several Shape Objects on the map that  have a transparency
 bcolor = GeoColor.FromArgb(48,128,0,0)
When I draw this shape it Look Great.
however , if I remove the shape from the layer
mylayer.InternalFeatures.Clear()
then re add the shape  I find the transparency slowly goes away.
These features are constantly changing and I have to update them every  10 seconds.
My Approach is the Clear the Feature layer  then re add the updated items.
each update causes the Transparency to become less significant to the point that after a minute it is completely solid.
 the style for the object is defined as
    ValueStyle.ValueItems.Add(New ValueItem(name, AreaStyles.CreateSimpleAreaStyle(fcolor, lcolor, lwidth, LineDashStyle.Solid)))
One thing I have noticed is that it only seems to happed with a fill color.
Drawing a line with transparency doesnt seem to be affected.
Any Thoughts would be appreciated.
Hi Steve,
 Could you please provide a sample which could recreate the issue? Then we can debug it and find out the problems quickly.
 Edgar
sub testfill()
Public SectorLayer As InMemoryFeatureLayer = New InMemoryFeatureLayer() '
  Public MainOverlay As LayerOverlay = New LayerOverlay()
     SectorLayer.FeatureSource.Open()
        SectorLayer.Columns.Add(New FeatureSourceColumn("Name"))  'Each Sector has a name
        SectorLayer.Close()
   MainOverlay.Layers.Add(SectorLayer.Name,SectorLayer)
    Form1.WinformsMap1.Overlays.Add("MainOverlay", MainOverlay)
Dim Points(5) as string
points(0)= "-75.123 45.123"    ' Create the Points for a square
points(1) = "-75.223,45.123"
points(2) = "-75.223 45.223"
points(3) = "-75.123  45.223"
points(4) = "-75.123 45.123"
 dim fill as geocolor
for i=1 to 100
     thread.sleep(1000)  ' wait one second
     fill = geocolor.fromargb(25,255,0,0)  '   Mostly transparent red
     drawpolygon("Test",Sectorlayer,points,geocolor.simplecolors.yellow,fill,2)
next i
end sub
Public Sub DrawPolygon(ByVal name As String, ByRef lyr As InMemoryFeatureLayer, ByVal pts() As String, ByVal lcolor As GeoColor, ByVal fcolor As GeoColor, ByVal lwidth As Integer)
        'create a polygon
        ''   Dim poly As PolygonShape
        Try
            lyr.InternalFeatures.Remove(name) 'Attempt to remove the feature if it exists.
        Catch ex As Exception
        End Try
        Dim columnValuesForLine As New Dictionary(Of String, String)
        columnValuesForLine.Add("Name", name)
        Dim ValueStyle As ValueStyle = New ValueStyle()
        ValueStyle.ColumnName = "Name"
        lyr.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(ValueStyle)
        lyr.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        Dim lstring As String = "POLYGON(("
        For p As Integer = 0 To pts.Count - 1
            lstring &= pts(p)
            If p < pts.Count - 1 Then lstring &= ","
        Next
        lstring &= "))"
        ''  poly = New PolygonShape(lstring)
        Try
            lyr.InternalFeatures.Add(name, New Feature(BaseShape.CreateShapeFromWellKnownData(lstring), columnValuesForLine))
        End Try
    End Sub
 So I let the application run for about 10 minutes .  updating every 10 seconds.
 The result was that the Map.refresh took longer and longer to the point the system appeared to lock up.
 This leads me to believe that although the layer visibly clears , there is some sort of memory hole. The previously removed items are still there.
 Does a layer.internalfeatures.clear()   actually remove the items or just make them invisible.
 Again. this only appears to be an issue with Polygon Fills.
Hi Steve,
 Thanks for your code, the reason is that you put the lyr.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(ValueStyle) in the method which will loop 100 times, so the customStyles become more and more so the polygon would be drawn many times, please set the styles  outside of the loop and everything will be OK.
 Edgar
Ahh. That actually makes sense.  The reason I have it this way is because the Styles can change every iteration.
 Can the custom styles be removed along with the features?
I think so, you may clear the customstyles and add a new one into it every time.
Absolutely…we’ve had code in place to restyle several layers on demand for a couple of years:
 facilityLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Clear();
 facilityLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(normalFacilityStyle);
 facilityLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
 Allen
 Perfect.  That’s what I was missing.
Hi Allen,
 Thanks for providing that code!
