Hi
I'm seeing labels chopped off on the map. Looks like it is where they cross a tile.
Is this a bug or is there a way to configure this?
Cheers
Steve
Hi
Cheers
Steve
Steve,
I've seen this myself and have only recently set the following properties and appears to have solved it for me:
DrawingMarginPercentage -- On my tracking layer I set this to a high number like 300 and now my labels always appear in their full width. I was also seeing half point symbols like you have shown in your post. I'm not sure but believe setting this property also solved the partial circle symbols that I am using.
On your TextStyle also set these properties:
BestPlacement
SuppressPartialLabels
GridSize
TextLineSegmentRatio
OverlappingRule
DuplicateRule
FittingLineInScreen
Some of the above I believe are only for lines.
You'll have to experiement with the values to see what works for you.
Dennis
Thanks Dennis. DrawingMarginPercentage fixed the label problem.
Cheers
Steve
Thank you, Dennis, for making my job easier :-)
I'm now seeing bitmaps truncated on tile boundaries.
Any ideas on settings to fix this? DrawingMarginPercentage does not affect it and I went as high as 600.
Steve,
I think it’s a known issue since a long time, I check out working tracking system and find it which created at 23/02/2011 23:17:20, but still not resolved, because we can hardly solve it completely by using current tiling logic.
Sorry for inconvenience.
