Trying to add a Raster File SqlServerSpatial110.dll
 Hi All,
When i try and add a raster file i get the following issue
"System.DllNotFoundException: "Unable to load DLL 'SqlServerSpatial110.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)"
   at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass6.<DrawException>b__4()
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
I have followed the instructions on here, installed the 2010 C++ runtime libraries (microsoft.com/en-us/download/details.aspx?id=5555), but i can't seem to find this dll anywhere to copy across?  I also don't have a Syswow folder, please see attached image.
I am running windows xp 32 bit.  any help would be greatly recevied.
Dan
Hi Dan,
This is a known issue first reported in this thread: gis.thinkgeo.com/Support/Dis...fault.aspx
At this time the only option is to add the SqlServerSpatial110.dll to the System32 folder of your system. To get you this dll a Customer Portal Ticket has been created for your organization. Please login to helpdesk.thinkgeo.com to access.
Many thanks this worked a treat!
 Dan
Your welcome. :)
