Two maps side-by-side
I'm trying to use two instances of the WinformsMap control on the same form.  The problem I'm having is when I click on the left map to pan some of the layers disappear until I release the mouse button.  Then the next time and subsequent times I pan on the same map it works fine as I see everything even as I move the cursor.  But when I click on the right map to pan the layers disappear.
It's not as frequent if I put all of the layers in the same overlay, but once I use multiple overlays it is nearly everytime.  It's almost like there is a refresh going on as soon as the map gains focus and it doesn't finish refreshing until I release the mouse button.  Any ideas?  Thanks in advance,
Chad
Chad,
 Can you give us a more detailed description of your case? How are organized your layers in each map? Are they exactely the same? If you have the same layers in both maps, I would suggest you have different instances of layers for each map while referencing to the same files.
 Also, I don't know if this is what you are trying to accomplish but I let you know that we have a couple of Code Community samples that show how to handle a mini map which is a second map to help navigate on the main map and shows how to handle issues of having two maps on tha same form. You can check the samples Mini Map Adornment Layer and Mini Map with Google Map.
wiki.thinkgeo.com/wiki/Map_Suite_Wp...ment_Layer
wiki.thinkgeo.com/wiki/Map_Suite_Wp...Google_Map
Val,
That was exactly the issue.  The two maps were referencing the same layers and overlays.  Once I created different instances of the layers to reference the same dataset it worked flawlessly.  Thanks!
Chad
Chad,
   I am glad that we pointed you to the right direction for that. If you have any other question, let us know.
