Unable display Labels on the marker image
Hi ThinkGeo.
I am getting no image on the marker if I try to add label on it.
I attach the code (based on the code file SetTheZoomLevelsOnAMarker.aspx.cs from the samples) to the posting. I don't know what is missing in it to display label on the marker
Anil
LabelingNotWorkingOnAMarker.aspx.zip (1.29 KB)
Hi, Anil
Thanks for your codes.
I can run it well in my local machine, and the images and labels can be displayed also. So if you can’t display images on the marker please check whether the “theme” folder exists; you can find it in the “HowDoISamples\CSharp Samples” folder.
If the problem still exists, please provide us more information to demonstrate it, such as the screenshot for it.
Khalil
Hi Khalil,
I attach the snapshot of the result of markers (with or without text).
If I set the size (parameters) of the WebImage then I do get the label on the marker. This thread can be closed now.
Anil
LabelOnMarker.zip (291 KB)
Hi, Anil
I guess that I know why this problem occurs. Anyway this bug has been fixed a few days ago and it should be disappeared in the latest development auto builds.
Khalil
