Unable to add more than 20 zoom levels
I need to be able to zoom in within a few feet. To do this, I thought I could just add custom zoom levels. However, I’m unable to zoom in any further than the original 20 zoom levels no matter how many I add to the customzoomlevel collection. Code below:
var partitionedZoomLevelSet = new ZoomLevelSet(); //make custom zoom levels to zoom in further than default
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[0].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[1].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[2].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[3].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[4].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[5].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[6].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[7].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[8].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[9].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[10].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[11].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[12].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[13].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[14].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[15].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[16].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[17].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[18].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[19].Scale));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[19].Scale / 2));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[19].Scale / 4));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[19].Scale / 6));
partitionedZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(GlobalObjects.Instance.OnyxMap.ZoomLevelSet.GetZoomLevels()[19].Scale / 8));
MyMap.ZoomLevelSet = partitionedZoomLevelSet;
The map is in decimal degrees, unprojected.
Hi Dan,
I build a test project, and it looks the scale can be zoomed in deeper.
And I think if you set map.MinimumScale it should zoom better.
As below is the test project, please view it.
9536.zip (101.6 KB)
Thanks, that seemed to work. One question, do I have set each layer’s zoomlevelset to the custom levels or does it do it automatically?
For instance, I have a lot of layers set up like this:
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(FontValueStyle);
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Will the above ApplyUntilZoomLevel work for the custom levels as well?
Hi Dan,
Yes you’re right, the ApplyUntilZoomLevel works for custom style also.
