Unable to cast object of type 'ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer' to type 'ThinkGeo.MapSuite.Core.InMemoryFeatureLayer'
My Controller Code is as below:
 <MapActionFilter()> _
    Function EditShape(map As Map, args As GeoCollection(Of Object)) As String
        Dim dynamicOverlay As LayerOverlay = map.CustomOverlays(“DynamicOverlay”)
        Dim shapeLayer As InMemoryFeatureLayer = dynamicOverlay.Layers(“sql2008Layer”)
        Dim featureJson As String = MapHelper.ConvertFeaturesToJson(shapeLayer.InternalFeatures)
        shapeLayer.InternalFeatures.Clear()
        Return featureJson
    End Function
In .vbHTML File:
<img class=“imgBtn” src="@Url.Content("~/Content/images/btn_edit.png")" id=“buttonEditShape” onclick=“editShape();” alt=“Edit Shape” />
 function editShape() {
        Map1.ajaxCallAction(’@ViewContext.RouteData.Values(“Controller”).ToString()’, “EditShape”, null, editShapeCallback);
    function editShapeCallback(result) {
        var features = Map1.getFeaturesFromJson(result.get_responseData());
        var editOverlay = Map1.getEditOverlay();
        editOverlay.addFeatures(features);
        Map1.getDynamicOverlay().redraw(true);
        Map1.setDrawMode(“Modify”);
When I run it Show me Error:
“Unable to cast object of type ‘ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer’ to type ‘ThinkGeo.MapSuite.Core.InMemoryFeatureLayer’.”
Hi Yogesh,
 The possible problem should be in the code as following:
 I guess the specific layer “sql2008Layer” added to the “map.CustomOverlays(“DynamicOverlay”)” is not a InMemoryFeatureLayer, it’s should be SQLServer2008FeatureLayer, can you check if you give the correct layer id here?
