Unlicensed Error
Hi
I have just upgraded an application from 3.x to 4.x and all I'm seeing when I run is Unlicensed.
I have tried using both the weak and strong named assemblies and get the same error both times.
Please help!
Cheers
Steve
Steve,
   When you say ‘upgraded an application’ what do you mean?  Are you talking about running on your development machine in debug?  Did you install the full installer, are you running the evaluation?  Did you just drop the new assemblies in the bin folder on another machine?  I will be around for the next 5 hours or more so we can help in real-time (ish).  Once I get the answer to this let us formulate a response and worst case we can do a GotoMeeting with you to help you out.
I downloaded and installed full version 4.0 to my laptop.
I copied a demo application that I had written around 3.x from another pc to my laptop.
Deleted references to 3.x dlls and cleaned the application.
Added references to 4.x dlls and rebuilt.
Cheers
Steve
And yes, running in debug on a dev machine. VS 2010.
Thanks for fast response BTW!
Cheers
Steve
Steve,
   Can you try and run the How Do I Samples and let me know if they work?   Are you up for a GotoMeeting now?
It’s the quickstart sample I’m trying to run.
 Yes, up for GotoMeeting
 Steve
Steve,
   It was good working with you and glad we could solve your problem.  Nice to see a 2.0 install moving to 4.0. :-)  Let me know if you have any more issues.
Thanks David
 Fantastic customer support.
 Cheers
 Steve
Steve,
  Our pleasure…  Just writing this so it closes the thread out from our support system. :-)
