Our comapny uses URL Rewriting on our website to remove any extensions from the web page. For example a url of mywebsite.com/home.aspx would show as mywebsite.com/home instead. It's a requirement for me to work within the URL Rewriting paradign so I must find a solution before we can purchase. When ever the URL rewriting occurs on a page that has the Map Suite Web Edition I get the following error:
[ArgumentOutOfRangeException: StartIndex cannot be less than zero.
Parameter name: startIndex]
System.String.Remove(Int32 startIndex) +2983124
ThinkGeo.MapSuite.WebEdition.Map.get_xe7887073020da841() +154
ThinkGeo.MapSuite.WebEdition.Map.SaveViewState() +1255
System.Web.UI.Control.SaveViewStateRecursive() +187
System.Web.UI.Control.SaveViewStateRecursive() +106
System.Web.UI.Page.SaveAllState() +168
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1099
If I change the URL Rewriting to have any type of extension it seems to work fine. For example I changed it to mywebsite.com/home.jhj and it worked fine again, so it seems that it doesn't care about the extension but only that it must exist.
Is this a bug or is there a work around?
